17x10 +18 would be my pick for a R33 GTR. 9" +35 is too thin and offset is too high, +18 is a bit better than standard, but if u were going to have a 17x9 id stick with stock R33 GTR rims as they are better quality than the enkeis. 17x9.5 +38 is too high offset, +18 would work, but honestly if i was going to spend the $$ id do it right first time and go 10" wide. gives u more options.
Thanks, I'm having a look around and most tyres that are 255/40/17 or 265/40/17 are a large difference in price, which would be my main reason for going for the 9.5".
However the difference between 9.5 and 10" is about 7mm more sticking out in the 10" and 1mm less clearance, so the 10" is looking more tempting, I *could* run 255/40/17 on a 10" but might be a little stretched....
But I saw this section of this thread and 255 don't look stretched on 10" rims, hmm 10" is looking good.
Skyline model = r33 gtst
Wheel diameter = 20"
Wheel width = 8.5"f 9.5"r
Wheel offset = ?
Tyre size = 225/35/20f 245/35/20r
Modifications to fit = roll guards a little.
sometimes scrubs when turning and hitting bumps together.
Skyline model = r32 gtst
Wheel diameter = 18"
Wheel width = 8.5
Wheel offset =
Tyre size = 235/40/18
Modifications = car is lower and has the big R33 front brakes
(best pic i could find to show how low it really is) (is the tires and wheels specs above)
any one had a problem with the inner side of the tire scubbing the top of third link front only?
Edited by nissans52
Skyline model = '97 R33 GTST
Wheel diameter = 17
Wheel width =8s, 9s
Wheel offset =+40 +40
Tyre size = 235/45
Modifications to fit = None
Fit good. May consider 10mm or 20mm spacers at some point after I lower it a bit. May go for a lower profile tyre also.,
Edited by Battery_backup
hey mrbenno,
can u email me at [email protected] ?
sorry im not able to send u a private message as im still new.. im interested to see how your emotions look on your gtr32, as im planning to get thjose too, same size offset and width..
thanks
Skyline model = 1989 R32 GT-R
Wheel Brand = Work Emotion XT7
Wheel width = 9.5"
Wheel offset = 20
Tyre size = 245/40/18
Modifications to fit = None.
Car is quite low, as low as a set of super low springs if you had them. ( I have Teins)
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
