no you just said that they weren't based off manufacturers,
Did I?
....Whilst Australian Standards are developed in conjunction with manufacturers (along with engineers, industry professionals and international associations)...
where does it say that?
Look Fellas, I didn't come on here to argue fact versus fiction with you. I simply tried to provide some facts about what's legal and what's not, and as I have said numerous times, it's up to the individual to use those facts as they see fit. If like yourselves people choose to ignore the facts, then so be it. It's got nothing to do with me and as Braddd has pointed out it's up to the police to enforce them. However we have already proven that bogus advice has already cost one user alr33x a defect, so where's the harm in clearing up the confusion? I'm sure if he knew the legalities before fitting said tyres he might not have done it.
I never said a stretched tyre is unsafe....
I never said don't do it....
I'm still trying to figure out what you are arguing about here...how can people make an educated decision if they don't have both sides of the story?
Facts do not cease to exist because they are ignored.
Edited by thewheeldeal.com.au
i made a statement that the ADR's didnt carry any merit of their own (them doing individual testing themselves), you said that was true, from this we deduce that you think that ADR's are based off them doing their own testing.
bigger turbo, fuel system, computer, fmic, steel induction etc etc etc, i'd be glad if i only copped a defect for tyre size :ninja:
and dont say that it'd get me pulled over and then checked, as we all know coppers love to pull over skylines no matter what the wheel/tyre situation anyway
hey guys just wondering... i have a r34 gtt and want to know what size rims i can get without any modifications. i got a quote from work and they seem to think i can have 18x9 front and 18x10 back. didnt say anythink about offset. offset and tyre sizes would be a big help thanks. also whats the biggest i can go legally??
Edited by pplatr34
also still running stock suspention and i dont mind rolling my rear gaurds alil. after reading alot of these pages i think rear: 18x10 + 18
front: 18x9 + 12 should do the job.
Edited by pplatr34
Pretty agressive. Should look good. You'll have to roll front and rear I believe.
ok so ive been told that theres abit involed in fitting those size on. can any1 reccomened the offset for work xd9z to fit snug in stock gaurds?
Edited by pplatr34
Just copy and fill in the table;
Skyline model = r32 gts-t 4door
Wheel diameter = 18"
Wheel width = 8.5 front / 9.5 rear
Wheel offset = +30 front / +35 rear
Tyre size = 225/40 front / 245/40 rear
Modifications to fit = Need low profile tyres to clear the control arms up front. Rears stick out about 2cm past guards so need stretch fit tyres
Hi guys,
can anyone tell me the offset that would fit flush with the 33 guards
front 18x8.5
rear 18x9.5
been reading this topic but just cant find it, always slightly in or out
that shit is useless without offsets mate...
find out the offsets first
is that all i have to do???????
Sorry I don't know 34s that well. It'll look good. Just might cost a bit to make them fit. I think guards will need bit of a pump.
I know a mate is running 18x10's +22 on his 34 and they fit ok with 235's front and back so going by that you'll be 4mm wider at the back and about 2mm further in at the front if you use a 235 tyre. Or maybe he has 245's.... I can't remember. Anyway his didn't scrub.
I'd go 235's front and 245's at back and make em fit.
need some help here guys.
17 x 8 up front
17x 9 on rear, +44 offset, kinda homo atm as you can see in pic below
ill be pickin up four 25mm bolt on spacers tomoz and see how it looks....
keepin in mind this is track only, thinkin maybe a slight flare on teh guard as well...
wondering if any one knows what size spacers ill need if i want to fill the guards on my r32 gts-t running r34 gt-t stockies, i want the wheels to sit further out to look abit more agressive as i like the look of the r32 wheels.
cheers.
The question of what wheel size fits what Skyline comes up so often I though this might be a good place to post your own wheel dimensions.
Skyline model =
Wheel diameter =
Wheel width =
Wheel offset =
Tyre size =
One of mine as an example;
Skyline model = R32GTST
Wheel diameter = 17"
Wheel width = 8"
Wheel offset = 35
Tyre size = 245/45/17
Modifications to fit = remove the front inner plastic guards, roll rear lip slightly.
:) cheers :)
got pictures of how the wheels sit?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
