no you just said that they weren't based off manufacturers,
Did I?
....Whilst Australian Standards are developed in conjunction with manufacturers (along with engineers, industry professionals and international associations)...
where does it say that?
Look Fellas, I didn't come on here to argue fact versus fiction with you. I simply tried to provide some facts about what's legal and what's not, and as I have said numerous times, it's up to the individual to use those facts as they see fit. If like yourselves people choose to ignore the facts, then so be it. It's got nothing to do with me and as Braddd has pointed out it's up to the police to enforce them. However we have already proven that bogus advice has already cost one user alr33x a defect, so where's the harm in clearing up the confusion? I'm sure if he knew the legalities before fitting said tyres he might not have done it.
I never said a stretched tyre is unsafe....
I never said don't do it....
I'm still trying to figure out what you are arguing about here...how can people make an educated decision if they don't have both sides of the story?
Facts do not cease to exist because they are ignored.
Edited by thewheeldeal.com.au
i made a statement that the ADR's didnt carry any merit of their own (them doing individual testing themselves), you said that was true, from this we deduce that you think that ADR's are based off them doing their own testing.
bigger turbo, fuel system, computer, fmic, steel induction etc etc etc, i'd be glad if i only copped a defect for tyre size :ninja:
and dont say that it'd get me pulled over and then checked, as we all know coppers love to pull over skylines no matter what the wheel/tyre situation anyway
hey guys just wondering... i have a r34 gtt and want to know what size rims i can get without any modifications. i got a quote from work and they seem to think i can have 18x9 front and 18x10 back. didnt say anythink about offset. offset and tyre sizes would be a big help thanks. also whats the biggest i can go legally??
Edited by pplatr34
also still running stock suspention and i dont mind rolling my rear gaurds alil. after reading alot of these pages i think rear: 18x10 + 18
front: 18x9 + 12 should do the job.
Edited by pplatr34
Pretty agressive. Should look good. You'll have to roll front and rear I believe.
ok so ive been told that theres abit involed in fitting those size on. can any1 reccomened the offset for work xd9z to fit snug in stock gaurds?
Edited by pplatr34
Just copy and fill in the table;
Skyline model = r32 gts-t 4door
Wheel diameter = 18"
Wheel width = 8.5 front / 9.5 rear
Wheel offset = +30 front / +35 rear
Tyre size = 225/40 front / 245/40 rear
Modifications to fit = Need low profile tyres to clear the control arms up front. Rears stick out about 2cm past guards so need stretch fit tyres
Hi guys,
can anyone tell me the offset that would fit flush with the 33 guards
front 18x8.5
rear 18x9.5
been reading this topic but just cant find it, always slightly in or out
that shit is useless without offsets mate...
find out the offsets first
is that all i have to do???????
Sorry I don't know 34s that well. It'll look good. Just might cost a bit to make them fit. I think guards will need bit of a pump.
I know a mate is running 18x10's +22 on his 34 and they fit ok with 235's front and back so going by that you'll be 4mm wider at the back and about 2mm further in at the front if you use a 235 tyre. Or maybe he has 245's.... I can't remember. Anyway his didn't scrub.
I'd go 235's front and 245's at back and make em fit.
need some help here guys.
17 x 8 up front
17x 9 on rear, +44 offset, kinda homo atm as you can see in pic below
ill be pickin up four 25mm bolt on spacers tomoz and see how it looks....
keepin in mind this is track only, thinkin maybe a slight flare on teh guard as well...
wondering if any one knows what size spacers ill need if i want to fill the guards on my r32 gts-t running r34 gt-t stockies, i want the wheels to sit further out to look abit more agressive as i like the look of the r32 wheels.
cheers.
The question of what wheel size fits what Skyline comes up so often I though this might be a good place to post your own wheel dimensions.
Skyline model =
Wheel diameter =
Wheel width =
Wheel offset =
Tyre size =
One of mine as an example;
Skyline model = R32GTST
Wheel diameter = 17"
Wheel width = 8"
Wheel offset = 35
Tyre size = 245/45/17
Modifications to fit = remove the front inner plastic guards, roll rear lip slightly.
:) cheers :)
got pictures of how the wheels sit?
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
