Hi guys,
I'm looking at some Tri spoke rims for my r33 gts-t. They're being sold without tyres. Basically, these are the specs:
17x9 20+ fronts
17x9 35+ rears
I know little about offset etc, but will these wheels suit my 33? Please bear in mind that the car is lowered slightly, but I do with to go lower down the track with coilovers etc.
front perfect rear to sunken, but they are tri spoke so i wouldnt buy them there ugly as.. all sorts of fail.
Here's my wussy fitments lol
Skyline model = R33 GTST
Wheel diameter = 17"
Wheel width = 8 front / 9 rear
Wheel offset = +35 front / +38 rear
Tyre size = 235/45 front / 245/40 rear
Modifications to fit = None, straight bolt up. Very safe fit
I really like Tri Spokes, i've always had a thing for them, so they suit me fine. You mention that the rears will be too sunken? Will they look noticeable shite? Or is it something that could be compensated for with wider tyres etc? Basically, i'm just worried that they will look out of place given that the offset is rather different between front and rear : ( Can anyone explain? As i'm not very good at this business.
It will look wierd. It's 15mm different. A 15mm spacer for the rear will fix it up easily.
Are the tri spokes super advans?
Aaah damn it. Oh well, i'm walking away from that transaction then. FYI the rims are Zeldas. Some people will hate them, but I really liked them.
Sometimes you just have to look at it and say, 'it wasn't meant to be'.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
