a little camber on the fronts couldn't hurt...
now roll those guards and slam that bitch!
im running -2.8 atm, can't get anymore without getting some aftermarket LCA.
ahaha don't think i be slaming her just yet.
also i don't mind if they hang out ahahaha
sorry i didn't introduce myself at the dyno day today billy... i only worked out who you were when you drove off today lol
your car looks mint with those sizes, and the black worked sooooooo well!
Hi all,
I have 33 GTR, it's lowered with Cusco Zero2 coilovers.
I was wondering what would I need to do to my R if I want to put 18x10.5 +/-0 (there is a pair of SSR Sp1 in this size for sale on ns.com, that I'm tempted to buy this pair and order new pair)?
Or I may be better off buying 18x10 +18 and leave the ride height as is (345mm guard to centre front and 335mm rears)?
Thank you in advance.
Cheers
Grant
Seen heaps of people with 10.5 +12, so 10.5 +/-0 would need fair bit of work also 245/40/18 is alright for it to stretch over 10.5"?
I'm thinking roll the guards, lower it a bit more, anything else I may need to know?
I have 19x9.5" +12 (selling it now) rays fortessr, it fitted inside guards so would need to look at heaps of pics with 10.5 +12 to give me some ideas.
Cheers
Grant
245 will fit but it'll be a *bit* of stretch depends what your comfortable with i dont know much about stretch on gtr's since i gotta gtst... but yeh to make it fit, roll, stretch, low but possibly camber OR flare depends how it sits.. post a pic if u got one of 10.5 +0
Hmm...
Might have to make an time for inspection of the rims I mentioned earlier and see what I'm getting myself into.
Alex, thanks for your help.
Cheers
Grant
haha all good dude, I thought it was you...
Cheers
Grant
Im also really tempted to get those wheels.... I have an offer for my wheels but its a hard choice to make.
I'd need some crazy stretch 225/45 and some more guard work though.....
8mm slip on is huge.. get 10mm bolt on hubcentrics if u can
run 10mm hubcentric spacers ! are they concave front and rear ? post pics
so i ended up with 10mm bolt on hub centric spacers at the front :down:
only pic i have so far showing the fitment... comments welcome.
Skyline model = R33gts
Wheel diameter = 18"
Wheel width = 9.5"
Wheel offset = +12
Tyre size = front-235/40/18, rear-245/40/18
Modifications to fit = rolled lip front and rear, front plastic removed, rear camber arms (dont really have to have them, just helps)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
