Hey guys,
Have narrowed my choice of rims down to two (for my 32 gts-t):
1. F: 18x8.5 +22
R: 18x9.5 +22
2. F: 18x9.5 +18
R: 18x9.5 +18
I realize the second option is quite aggressive, especially for a gts-t front, and would probably require lot of camber and stretching.
Thoughts? Opinions? All welcome...Thanks
Brake clearance, depend on rim design - what rims are you getting btw?
You'd need to run 245/40 tyres and roll the guards for sure. And maybe dial some camber for good measure.
Hey guys,
1. F: 18x8.5 +22
R: 18x9.5 +22
2. F: 18x9.5 +18
R: 18x9.5 +18
I'd go for 2nd option if you don't mind doing the work required to fit. It'll look tough kinda reminded me of Abu's old R32 GTST.
1st option seems to be safe.
Really, it's up to you as in how prepared you are to make it fit.
Brake clearance will depend on the wheels design mostly, not offset.
They will hang out of your guards roughly 10-15mm so yes depending on how low you go you'll wanna roll and maybe flare your guards depeding on tyre width.
volk te37
Would a 19x10.5 + 12 all round, be suited better ?
What do you guys recommend ?
*edit* also what tyres all round ? 245, 255 ?
Edited by KISIN
TE37 have plenty of room to fit big brakes especially 19" diameter rims.
19x10.5 +12 is better suited for 33 GT-R.
As for tyres, 265/35 or 275/35, 33 GTR have plenty of room under the guards, maybe a minor guard lipping would suffice but once again it's up to tyres style.
+12 is perfect, I've got 10" +12s, sits maybe 2mm out of the guards.
Will have a chunky-ish kit put on so im worried they will look sunk in the guards...but i think it should be spot on then with 19x10.5 +12 and 275's....
thanks guys!!
r33 1998
20 inch
8.5 wide
35 offset
225 front 245 rear
look nice big 20s but everyday driving car being lowered almost 2 inches had to roll guards and remove innner plastic
you really feel the bumps and really have to watch out for pot holes .19s or smaller are probably better for everyday but something always have to be compromised looks or performance.
  • 3 weeks later...
Skyline model = R31 Aus Spec
Wheel diameter = 18in
Wheel width = 7.5in
Wheel Offset = 40
Tyre size = 225/40
Modifications to fit = 5mm Spaces On Front to clear Strut/Spring Plate, 30mm bolt ons for the rear ONLY for looks.
Looking at putting
F - 19x8 - 55 Offset
R - 19x10 - 37.5 Offset
Recon these will fit?
Hey everyone, Need help before i buy new wheels!
Wheels: Work Emortion 11R 18x9.5 +12 all round on a R34 25GT
Thinking I'll need stretched tyres and rolled guards ?... Anything else ?
Help greatly appreciated and thanks in advanced !
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
