Dont run staggered setup on GTR...and get the 10s +22 with a 265 tire. Should all sit in nicely front and back. Sorted.
Have a look back at my pics of 32 GTR, they are 10s all round +11R and +12F with 265s all round. Yours will sit in a full cm in comparison.
It's rolling diameter of tyres that have to be within 2-4% (can't remember exact percentage) otherwise ATTESSA stuffs up.
Width and offsets aren't the issue, a friend told me about a 34 GTR had 4wd issues and mechanic lined all 4 wheels and noticed 4 tyres are different (all are purchased brand new in same size all round), that was enough to stuff the 4wd up.
ah yeah, iv heard of that with the ATTESSA. Not about width differences tho. Having said that it is easy to changing said rolling diameters by unknown quantities as as 225/35/18 is not going ot have the same rolling diameter as a 275/35/18 right?....
does anyone know if 19x10 +20 will sit flush with r33 gtr guards?
It'll fit easily providing you low it.
also what size spacer to make r34 gtr wheels it sit flush with r33 gtr guards?
25-30mm spacers + low will have this wheels fit flush in 33 GTR.
Thanks
yeh wont fit that under stock front guards without stretch/camber/guard bashing.
i think its important that people dont just say "it'll fit fine" unless it actually will.
fitting and been made to fit are not the same. :thumbsup:
im considering putting 18x9+15 F and 18x9.5+22 R on my standard guard 33
any advice?
Seems like a pretty nice fit to look aggressive on standard guards
will need front guard liners removed, all 4 guards rolled, and 225/40/18 fr 235/40/18 r
guards may need a lil pull, depending on height
depeneding on how much camber you are running and how low you are id say you will still be able to get 255's on those in the rear...
iv got 18x9.5 +36 with 275's. As little camber as the standard arms offer + pretty low n there is heaps of room. only just needing to roll the guards...
you can put better 235's on there.
a high quality 235 will give more grip than a cheap 265
agreed. I think alot of people make this mistake.
But a sticky & fat tyre... :)
that is my new 275/35/18 Toyo Proxes4 on a 9.5" rim (+36). Minimum camber and lowered a fair bit (bodykit is 14mm at lowest points on the front lip and side skirts).
See heaps of room left in the guards but sitting pretty flush
Edited by jjman
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
