er... dood... that's anything but low...
i would say that is just the perspective of the photo as i was trying to get a pic of how the new rubber sat etc. as such it makes the car look quite high as you are looking up into the arches
see my garage pics for normal perspective http://www.skylinesaustralia.com/forums/index.php?app=garage&do=view_image&id=3397
basically you can get your pinky finger in between the top of the tyre n the wheel arch- just
nonethless, horses for courses. I get alot of people commenting how low my car is. To other people its only low if the rims are up under the guards... (i.e. see my other garage pics with the series 1 spoiler n drift suspension)
it's still not that low... it's clearly below stock heaight, but it aint slammed
my point is that you cant run your car at that height and say that people can have low with 275's on a 9.5" +36 rim without flaring your guards or heaps of camber. if anyone tries to slam their car with those specs they will run into trouble.
i run my car lower than yours and had to pull my guards to fit 9.5+25 with a 245/40
exactly. One persons low is another person's stilts.
Worth clarifying in people's minds before they get in and assume a give rim/offset/tyre will fit...
:thumbsup: exactly
Wheel: Lenso/Raiden D1R (Project D)
Skyline model = 1994 R33 GTST
Wheel diameter = 18"
Wheel width = 8.5" Front, 9.0" rear
Wheel offset = +35 Front, +32 Rear
Tyre size = 245/40ZR18 Front 265/35ZR18 Rear
Modifications to fit = Roll Guards
Want to correct the camber a bit so may need to do something with the guards if I do that
Edited by 89CAL
Folks:
All this offset stuff messes with my poor old head...
I have an R33 GTS-T at the stock height.
I'm looking at some old Rays GT2s in 17" x 8.0" all round, with +33 offset.
No troubles with those? Any other thoughts?
Thanks!
Folks:
Thanks!
That will fit without any issues at all
they sit in the guads
Folks:
Thanks!
they'll sit in the guards alot
Folks:
Thanks!
the only useful thought i could provide is look for something better sized. Not saying go grab some 10" wide phat ass wheels but at least an 8/8.5 F and a 9/9.5 R gives you some more tread to work with AND looks 11bty timesbetter.
if you need any help with size/offsets for that let us know. :thumbsup:
as a general rule if you are running wider rubber its always worth rolling your guards at some point you'll likely lower the car too and it will be relevant then so for $50 or so a corner its a good investment to roll ya guards out the way cos if you dont and ya munch your guard cost ya more than $200 to fix it :thumbsup:
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
