Hi guys, thinking of getting some wheels for my r33 gtst off one of the traders. Been reading the thread but still wanted opinions from some of the more experienced members. I was looking at getting the following specs:
18 x 9 +15 for the fronts
18 x10 +15 for the rears
Looking at running 235s for the front and possibly anything above 235s for the rear. I will be purchasing camber arms and rolling/ flaring my guards as necessary. My questions are:
- how agressive is this fitment? I want to achieve the wide stance without overly sacrificing the life of my tyres. I do understand that camber will come into play, but I would like to avoid having to change my tyres every month just to achieve a particular look
- would 235s at the rear be sacrificing traction? If so, what would be a better recommendation? As I said I'm willing to roll/flare and purchase camber arms, so what combination would be best for the rear
Oh and I forgot to mention that I will be purchasing some coilovers also, but won't be lowering the car to a ridiculous height since I have a driveway I have to get in and out of. Any advice would be greatly appreciated.
id be keen to see the results of that combo, thats an inch wider than mine on the back, i dont think you want too much more camber on the back, its got enough already
it would be awesome round a track though.
Mate do you have any pictures of how your car sits? I'd like to have a visual just so I have a benchmark to compare against. And what did you mean about the camber in the back?
Just took the plunge and bought myself some Ame Circlar Spec R in 18x9 +15 and 18x10 +15 from one of the traders (Autotechnik). I'll post up some pics when all the work is done. Probably in a couple of months. :)
you'll need alot of camber in the rear, and the front on stock guards will fit with a roll but will have to stretch
tyre life wont be good at all.
should have pics of my 9.5+13 and 10+9 end of next week.
Awesome, looking forward to the pics. Also I spoke to PhilB (from this site and JDMST forums) and he said that he ran similar specs and for the rear, with a bit of rolling and a flare/pull he was able to minimise the amount of camber that had to be run. So fingers crossed I suppose. And luckily for me the skyline isn't a daily driver so hopefully that will minimise tyre wear. :)
My car for example. Previous wheel: (f) 17x9.5 +0 and ® 18x10.5 +15 lots of camber on the front, something like -4 and stretched tyres all round
Awesome, thanks for the photo blags. Car looks awesome!
pretty sure 10+15 will need fair bit of camber if you are only rolling, my camber arms are on full for the 10+20
So alex, your guards were just rolled? I'll be getting mine pulled and/or flared at the rear so hopefully this will allow me to run less camber. So what is the maximum camber setting at the rear for an r33 (in degrees)?
Anyone fitted 18 x 10 + 15 on there 32 gtr? any photos? modifications required?
was thinking of putting 255's or do you guys reckon definately 265's.
Cheers,
Thanks
did u end up fitting the 18x10 +15 rims, got pics or comments on the fit?
Thanks for input earlier guys, ended up getting the 18x10's with +22
So next question i have is tyres
Obviously there are so many to choose from but ones i'm looking at are Toyo's flagship T1 Sport tyres
Sizes i was considering were either 265/35, 275/35 or 285/35
I'm kinda leaning towards 275 at moment
Anyone know if i'll have any clearance problems if i choose the 275 or 285 options?
any updates? pics?
im looking at 18x10 +15 on R32 R
I'm running 18x10.5 +15 TE37s on an R32 GTR with 265/35R18 semi slicks on them and I had to get the guards rolled slightly and the rear raised a tad.
They stick out a little but look f**king awesome IMO.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
