im starting to think about getting new rims for my car, i have a 33 gtst with stock rims,
i think i will end up getting lenso D1R wheels in 18 inches and thinking 8.5 fronts and 9.5 rears,
not too keen on flaring the gaurds maybe a roll what off set do you guys think?
seen a lot of different numbers going around and it confuses the crap outta me, even used the offset calc, but still not sure if its right!
edit: also on stock ride height atm
edit edit: or should i look at something like 8 and 9's?
Im running D1R's. 17x9 +15 (might be +17, cant remember) and 17x10 +15 on the rears. Just rolled guards and they are fine.
I've got CR Kai's on my r33 that are 18 x 9.5 +38 front and +20 rear. I know the wider track is meant to be at the rear but the +20's wouldn't clear the front brake calipers.
Now that I've put some SK bilstein/whiteline coilovers in it (about 335mm from centre of wheel to arch front and rear) I notice the front is bottoming out inside the wheel arch over harsh bumps, and it isn't even that low!
Tyres are 245 x 35.
Is this because of the offset at the front?
Should I get 5mm spacers and switch the wheels around front and rear?
This is current ride height:
And this gives a better idea of offset difference before lowering:
Edited by copycutter
cripes. whats the handling like with the wider ones at the front?
does it tramline like a bitch or what?
iv never been an advocate of spacers but in this case- maybe...
Handles fine. I can't say I know exactly what tram-lining feels like but it corners well and doesn't understeer or do anything overtly untoward.
So is the source of my scrubbing the offset of the rim?
Just put new wheels on the front today. They scrub into the fender lining at full lock or going over pot holes.
What are your opinions on removing the liners? Bad/Good idea?
whats the specs on your front wheels?
just leave them in, helps keep the chassis/guards clean as well.
a little bit of scrubbing on the lining doesnt hurt, only when it scrubs on metal and starts chewing tyres then u got an issue lol
my splash gaurds are still in, 18x9.5 +30 only sometimes scrubs on full lock.
Fronts are 18x9+15. Just an update the scrubbing starts at about 1/4 to 1/2 lock when turning right instead of the full lock as i mentioned before.
The left doesn't seem to scrub from what I've noticed, though it's hitting into the fender when going over uneven/pot hole roads and tiny amounts of rubber are getting sliced off :(
I think the left front side is slightly higher then the right. Just seems weird as fender on the right isn't eating into the tyres, maybe its a camber issue?
edit: typos galore lol
Sorry my mistake I've got +38 rear and +20 front which is why the fronts are pumped out. Can anyone tell me if that front offset at that ride height is what's causing the wheel the scrape the liner over harsh bumps?
Im thinking of going 18x8.5 + 32 F with 225/40/18 and 18x9.5 + 38 R with 255/40/18 for my R34 GTT, from what i heard theres no need for any mods to make them fit.
Just need confirmation before i make a purchase, thanks :)
I'm certain these should fit fine without mods. I've had 18x10+22 on my rears with no mods, except until I got wider tyres :(
Looking at a set of rims at the moment their:
17x8 +45
17x9 +35
what would these fit like on an R33?
(Help would be much appreciated as I know very little regarding this)
http://www.boostclassifieds.com.au/advert/766888-Stm-Lightweight-Racing-Rims-1739-for-Sale.html
(link to the wheels in question)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
