http://www.ebay.com....=item2c600f34ae
how would these offsets fit/look on an r33 s2?
im assuming no mods to gaurds?
would fit well and not require any mods to the guards as far as i can tell even when fitting full width tyres to those rim sizes. (235/35 & 265/35). Cant garuantee it will if you plan to dump it on its arse tho...
Also cant comment on whether the spokes will clear the calipers but by the look of the design and the offset it should do.
rears would be ok but the fronts would be swallowed up under the guards with that kind of width n offset- n look shit IMO.
could spacers be used to push them out to fill out the guards more? or would they still look shit?
well spacers are always an option in their own right. but there are several issues with them.
1- they are illegal in most states (defect notice material)
2- it is very hard to get the wheel centred on there well with spacers which = vibration through the steering and excessive wear on your wheel assembly/steering system
3- it can also upset the handling
just thought id post up how i went with the rims:
Fronts: 17x8 +45, 235/45/17
Rears: 17x9 +35, 255/45/17
rears sit flush with guards, fronts sit flush but ended up using a 5mm spacer each side.
make sure she is all bolted up properly n then take it out for a run on the freeway and see if you have any steering vibration. (or does it wander easily or tramline etc)
Hey guys thinking of running XXR 526's on my 33 GTST.
18x9 +35
18x9 +25
Would these for without guard rolling etc? Only thing I'm mildly concerned about is that the spokes may not clear the standard brakes.
18x9 +35
18x9 +25
maybe, maybe not. at stock ride height probably but otherwise it would be touch n go. Tho u will also get away with it if you run stretched tyres. (but please dont, its sacrilidge...)
Anyone successfully pumped an inch more room out of 33 gtst rear guards?
easy, but there is chance of paint cracking... i'd say i got around an inch out of mine without cracking on the outside at all
great thread ,will post up pics and specs when i get my new wheels . hopefully next week :)
will want to lip them, but that's all
18x9.5 +12 on the front and 18x10.5 +22 on the rears ?i was thinking the rears might need a little flare ?fronts hopefully should be fine with some neg camber witch i'm allready running . but will only know once i get them on .
Edited by wannaslide
is this for a GTST? if so you are dreaming. Or crossing the border into mexico in a bad way.
if you can be bothered check thru the 'car parts' for sale section. There was a guy selling rims like this which he ahd on his GTST (red one from memory). There are pics. If its your thing then go for it.
But defect notices are also the cop's thing
Edited by jjman
i have 18x9.5+12 all round at the moment, and the 10.5+22 is only 3mm more
so yeh... easy fit with a roll/flare or camber. front guard liners will have to be removed
i dont run camber to fit my rears for traction reasons, but with a little pull they fit easily
sigh
yeah r32 gtst ,i'll have a look for that thread to see what your talking about . thanks
sigh
yeah i'm running 0 camber in the rears and about neg 2 in the fronts , anyways when i get them i will post pics of how they sit before any guard work is done .
And heres it on 18s.
18x9-1 215/40/18 *fronts*
18x10+16 235/40/17 *rears*
camber; -3deg front / -2deg rears
jjman
i couldnt find the forsale thread but i did find this ,thats the sort of flare i want on the rears and even though my rims will be half a inch wider front and back this guy is running heaps lower offsets ,so mine shouldnt be that bad ?
  • 3 weeks later...
Would 18x9.5 +22 wearing 265's all round fit a R33gtst with rolled guards on rge rear and no liners on the front STD guards?
Camber wise I run -3 on the front and -1.5 on rear with around 350 mm centre of wheel to guard.
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
