http://www.ebay.com....=item2c600f34ae
how would these offsets fit/look on an r33 s2?
im assuming no mods to gaurds?
would fit well and not require any mods to the guards as far as i can tell even when fitting full width tyres to those rim sizes. (235/35 & 265/35). Cant garuantee it will if you plan to dump it on its arse tho...
Also cant comment on whether the spokes will clear the calipers but by the look of the design and the offset it should do.
rears would be ok but the fronts would be swallowed up under the guards with that kind of width n offset- n look shit IMO.
could spacers be used to push them out to fill out the guards more? or would they still look shit?
well spacers are always an option in their own right. but there are several issues with them.
1- they are illegal in most states (defect notice material)
2- it is very hard to get the wheel centred on there well with spacers which = vibration through the steering and excessive wear on your wheel assembly/steering system
3- it can also upset the handling
just thought id post up how i went with the rims:
Fronts: 17x8 +45, 235/45/17
Rears: 17x9 +35, 255/45/17
rears sit flush with guards, fronts sit flush but ended up using a 5mm spacer each side.
make sure she is all bolted up properly n then take it out for a run on the freeway and see if you have any steering vibration. (or does it wander easily or tramline etc)
Hey guys thinking of running XXR 526's on my 33 GTST.
18x9 +35
18x9 +25
Would these for without guard rolling etc? Only thing I'm mildly concerned about is that the spokes may not clear the standard brakes.
18x9 +35
18x9 +25
maybe, maybe not. at stock ride height probably but otherwise it would be touch n go. Tho u will also get away with it if you run stretched tyres. (but please dont, its sacrilidge...)
Anyone successfully pumped an inch more room out of 33 gtst rear guards?
easy, but there is chance of paint cracking... i'd say i got around an inch out of mine without cracking on the outside at all
great thread ,will post up pics and specs when i get my new wheels . hopefully next week :)
will want to lip them, but that's all
18x9.5 +12 on the front and 18x10.5 +22 on the rears ?i was thinking the rears might need a little flare ?fronts hopefully should be fine with some neg camber witch i'm allready running . but will only know once i get them on .
Edited by wannaslide
is this for a GTST? if so you are dreaming. Or crossing the border into mexico in a bad way.
if you can be bothered check thru the 'car parts' for sale section. There was a guy selling rims like this which he ahd on his GTST (red one from memory). There are pics. If its your thing then go for it.
But defect notices are also the cop's thing
Edited by jjman
i have 18x9.5+12 all round at the moment, and the 10.5+22 is only 3mm more
so yeh... easy fit with a roll/flare or camber. front guard liners will have to be removed
i dont run camber to fit my rears for traction reasons, but with a little pull they fit easily
sigh
yeah r32 gtst ,i'll have a look for that thread to see what your talking about . thanks
sigh
yeah i'm running 0 camber in the rears and about neg 2 in the fronts , anyways when i get them i will post pics of how they sit before any guard work is done .
And heres it on 18s.
18x9-1 215/40/18 *fronts*
18x10+16 235/40/17 *rears*
camber; -3deg front / -2deg rears
jjman
i couldnt find the forsale thread but i did find this ,thats the sort of flare i want on the rears and even though my rims will be half a inch wider front and back this guy is running heaps lower offsets ,so mine shouldnt be that bad ?
  • 3 weeks later...
Would 18x9.5 +22 wearing 265's all round fit a R33gtst with rolled guards on rge rear and no liners on the front STD guards?
Camber wise I run -3 on the front and -1.5 on rear with around 350 mm centre of wheel to guard.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
