hes talking -4 degrees camber on the rear. and has R33 gtr wheels. which as you said are 17x9 +30, and wants to add spacers to add more poke. which in my opinion is unnecessary. but then, im not mexican.
4 degrees is a silly amount of rear camber......mine has mininal camber(not sure how much) but already very slippery compared to stock
thats what i was clarifying however -4 camber on standard arms as previously stated is impossible even with sacking it to the ground...
But your absolutely right camber in rear is completely stupid and doesnt help the car handle at all on the road
Hey all just need an expert opinion on a set of rear wheels I am getting. Long story short, I waited a little to late to get a set of wheels I wanted. Now the store only has rears available in a 18x10 +40. I know this will not fit, I just wanted to know what size spacer I would have to run in the rear in order to make it sit flush with the guard? I also have two offest sizes available for the front 18x9 +24 and 18x9 +30. Which of these offsets will sit flush with the guard with no mods needed. Also, with spacer calculation say the rim is a +40 will a 5mm spacer then make it +35?
what car are we talking about here???
yep bingo :D
yep bingo :D
Wow!!!!! Thanks for the quick response. So sorry was rushing forgot to mention its a r33 gts-t. How big a spacer would you say is just to big and ya might as well get a rim with the right offset. I was thinking of putting a 10mm spacer on back. or a 5mm. Will a 5mm be enough for the rear wheel to clear the necessary parts?
Edited by Daboss
depending on the wheel size you have on now i would say you would have atleast 25 - 30mm less clearance on the inside of the guard (closer to the strut) and about 30-40mm more poke towards the guard.
complete guess there on rim sizes that you have but i rekon a 10mm spacer will get you out of trouble just fine :)
depending on the wheel size you have on now i would say you would have atleast 25 - 30mm less clearance on the inside of the guard (closer to the strut) and about 30-40mm more poke towards the guard. complete guess there on rim sizes that you have but i rekon a 10mm spacer will get you out of trouble just fine :)
Right now I am stock. Just wanted to make sure I get the fitment right for the rims I am about to get. To let you know what they are front 18x9 +24 or +30
and rear 18x10 +40 with a 10mm spacer. How does that sound. Which offset should I go with in the front for a flush fitment no mods? I was leaning towards the +30
IMO its always best to test fit or measure to ensure fitment you want.
if you dont want to agressive on the front go the 18x9 +30 and then the 18x10 +40 and add that 10mm spacer. may need to just roll the inside lip depending on tyre sizes but should be all ok :)
with that ull need to do more than roll the inside lip unless ur planning on running some camber or a stretched tyre (or keeping it at stock height).
Edited by jjman
Hey jjman, what all will I have to do in order to get those wheels to fit in your opinion? To give you an idea with what I am working with the car has rear camber arms and coilovers front and rear. This is a r33 gtst. The rims I have in mind are 18x9 +24 or +30 in the front with a 235 40 tire and in the rear 18x10 +40 with a 10 mm spacer cause the 18x10 +22 are no longer available, with a 265 35 tire. In the front will the +24 be a better fitment and if the have another color available with the +24 in the rear will that be a better fitment? Are those tire sizez ok? Please someone help cause I am about to purchase these rims tomorrow and do not want to get them if they are too much trouble. Do not want to run ridiculous camber in the front or rear as it is a daily driver that will be doing some drag runs from time to time.
18x9+24 still won't poke. That is a close to flush fitment, it will sit about 2-3mm inside the guard. Safe. Running 18x9.5+22 and it is poking around 5mm with 0 camber, your offset is 8mm further inset.
With the 18x10+40 issue, a 15mm spacer will push it out to the same as the picture linked, which is my 18x10.5+30 245/40
http://sphotos-d.ak....154939089_n.jpg
If you are going to push it out ^ that far, and slam it, you will need to run stretch and rolled guards unless you want to look mexican.
Edited by voncina
Can't see the pic as I am to work, but I want to run a 265 35 18 on the back with as flush a fitment as I can get. I don't want any poke just sitting flush with the guard and lowered.
Interesting.
I was thinking about going 18x10+38 on the back of my 33 gtst. Thought i had plenty of room on the inside. What are you expecting it will foul on. Shock / Strut? Need to remeasure...
265 is a pretty big tyre, maybe drop a size but either way you will have to lip the inside of the guard
Interesting.
more than likeley foul on the strut. drop the offset to low 30s
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
