For now I think I'll leave it as is.
Only to test the waters and see if I get any attention for having them.
Also my funds have dried up a little haha
I think the law is 25mm outside the guards? Not too sure on that one, is just what I heard.
I haven't got any cop attention at all, had cops pull up next to me and behind me.
But yeah the more you lower your car the more camber it will naturally give it. Anyway it does look boss man - check out my pics a few pages back - black on black, same rims haha.
EDIT: I see you commented on a pic of my car saying it was perfect fitment haha.
Edited by voncina
I saw in another thread on here where the guy rolled the front guard lip tight such that one of the tabs was holding the liner like a clamp. So basically kept the liners, and rolled tight. Not sure how robust that would be though.
Will see if i can find it again...
Found it:
http://www.skylinesaustralia.com/forums/topic/401848-trying-to-fit-my-dream-wheels-te37/page__view__findpost__p__6393854
You can see in one of the photo's how they used the tab to hold in the liner. Personally I would prefer to keep my liners when I roll. This looks like an option, but would be keen to hear others thoughts too.
in the pic below shows clearly that the tabs are not holding in the plastic guard liner (splash guard). Also looking at the pic seems it has a small flare pushing the guard out slightly
also this has not been rolled perfectly flat
Edited by Frosty
Put new wheels on today,(17x9+22 enkei rpf1s) and have ran into a slight problem, regarding those plastic guard liners.
They scrap on corners that have either got a bit of a dip during the apex or slight elevation or while descending.
If i remove them completely, is it possible for the wheel to still hit the guard at all? Am i able to push the guard out at all to stop this happening?
It used to happen even with stock R33 wheels as well. Any info would be great.
Car had an alignment today, it was only slightly out.
The car is sitting on bilsteins and king springs, it isn't as low as others i have seen, i can stick my foot between the wheel and the guard. With the new wheels pretty easily, at slow speeds aka 50kmh, on the stockies it did it only on corners that had a really bad dip during the apex (only in the hills), when the G's would have been at there highest.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
