For now I think I'll leave it as is.
Only to test the waters and see if I get any attention for having them.
Also my funds have dried up a little haha
I think the law is 25mm outside the guards? Not too sure on that one, is just what I heard.
I haven't got any cop attention at all, had cops pull up next to me and behind me.
But yeah the more you lower your car the more camber it will naturally give it. Anyway it does look boss man - check out my pics a few pages back - black on black, same rims haha.
EDIT: I see you commented on a pic of my car saying it was perfect fitment haha.
Edited by voncina
I saw in another thread on here where the guy rolled the front guard lip tight such that one of the tabs was holding the liner like a clamp. So basically kept the liners, and rolled tight. Not sure how robust that would be though.
Will see if i can find it again...
Found it:
http://www.skylinesaustralia.com/forums/topic/401848-trying-to-fit-my-dream-wheels-te37/page__view__findpost__p__6393854
You can see in one of the photo's how they used the tab to hold in the liner. Personally I would prefer to keep my liners when I roll. This looks like an option, but would be keen to hear others thoughts too.
in the pic below shows clearly that the tabs are not holding in the plastic guard liner (splash guard). Also looking at the pic seems it has a small flare pushing the guard out slightly
also this has not been rolled perfectly flat
Edited by Frosty
Put new wheels on today,(17x9+22 enkei rpf1s) and have ran into a slight problem, regarding those plastic guard liners.
They scrap on corners that have either got a bit of a dip during the apex or slight elevation or while descending.
If i remove them completely, is it possible for the wheel to still hit the guard at all? Am i able to push the guard out at all to stop this happening?
It used to happen even with stock R33 wheels as well. Any info would be great.
Car had an alignment today, it was only slightly out.
The car is sitting on bilsteins and king springs, it isn't as low as others i have seen, i can stick my foot between the wheel and the guard. With the new wheels pretty easily, at slow speeds aka 50kmh, on the stockies it did it only on corners that had a really bad dip during the apex (only in the hills), when the G's would have been at there highest.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
