this is bad advice! Not to mention these are illegal
Because slamming your car and having rims poking 10mm outside the guard isn't.
Hub centralising spacers are fine for daily use - if he told me he was tracking it I would have said no.
clearly you have no idea what is good and bad when it comes to suspension/wheels but im not going to get into an E fight with you...FYI i bolded that section of your quoted text for a reason!
let me know when you have some experience in suspension
How would fitting xxr002 16x8 +0 go for a r32 gtst coupe with 205/50 tyres? I'm wondering how brake clearance would be and if spacers would be needed. I have a guard roller and adjustable camber arms.
brake clearance shouldnt be an issue.....pretty agressive wheels tho! pics when fitted
he's got you there damo... you said illegal, which having rims out of your guards is :P
Won't fit over the front calipers. Knew itd be an issue but was being hopeful lol, time to buy spacers
Thought they would have fit easy, i have 15x10's on my 33 and they fit no problem
Edited by Autumn33
Chaps,
After reading through 115 pages of this thread, I have a bit better of an idea of what sized wheels I should be looking at, but this question is more R34 GTT specific.
I'd like to run
18 x 9 +20 Front (235/40)
18 x 10 + 12 Rear (245/40)
I currently only have Blitz ZZ-R coilovers fitted, but open to comments about what other kind of suspension components needed to run this setup.
Cheers,
Shazza
Chaps,
I'd like to run
Cheers,
Shazza
no issues with the coilovers there. Will need to lip the guards on the rear but the fronts will be no issues. would help if you had rear upper adjustable camber arms but shoud be able to squeeze them in without too much hassles
Hi Frosty,
Thanks for the quick reply. I intend on getting a set of rear camber arms, and front eccentric camber adjustable bolts for adjustment regardless.
Would a 255/40 fit on the 10" wheel on the rear, without much issues?
Cheers,
Shazza
Hi Frosty,
Thanks for the quick reply. I intend on getting a set of Cheers,
Shazza
255 is a big tyre you would want to run a smaller tyre unless you go mexican and run camber but then defeats the purpose anyway. if you look at my signature the one on the right is a R32 with 18x9.5 +12 all round with 235/40 an the GTT is roughly 15mm wider each side in the rear
not at all and only if its more than 25mm ;)
The wheel and tyre must be contained within the body work or mudguards (including any flares) when the
wheels are in the straight ahead position.
http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi09_rev4.pdf
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
