Depends on wheel type up front.
I had 9.5 +38 not clear the front brakes, but 8.5 +30 all good. Same exact brand and type of wheel, just more/less concave spokes.
Edit: rears I have used both 9.5 +20 (current) and 9.5 +38 (to test) and were fine with guards rolled and 235/45/18.
Edited by copycutter
Looking at running some Lenso D1R
18x8 +32 F with 225/40/18
18x10 +22 R with 255/35/18
car is stock height
Do these offsets sound right?
ive searched but every r34gtt seems to be running different offsets.
im hoping some one is running these rims and can confirm offsets before i buy.
my local tyre shops here have no idea- they asked me for offsets, and proceeded to tell me im an idiot for running a 255 on a 10" rim.
guess they dont want my money...
Alright, so
My CST Zero-1 Hyper's are finally in Australia, and I have a question.
The rims are 18x9.5 +15 all round.
I'm going to run a 265 35 tyre on the rear, and a 245 35 on the front
Do you think I'll have issues with this setup?
I'm thinking the front will be a little tricky.
Alright, so
which car?
easy fit on a 33 or 34 gts-t
will need to remove guard liners and roll the fronts fairly aggressively.
go for a 235/40/18 as opposed to a 245/35, it looks better (although very similar) and is cheaper.
Is 18x9.5 +15 f and 18x10 +20
215/45 going to be too aggressive for a stock 34gtt do you think?
lol that's a LOT of stretch... easily doable but I wouldn't feel comfortable with a 215 on a 10"
fitting rims with 235 fr and 255r would be easy
Ok their not 215 their 235 9.5 and 10"
Just got to see if the low offsets Wil fit.
Test fit this weekend
i just got 18x9.5 +25 front and 20 rear. they stick out a bit at the front standard GTT hub. if you want a really flash fit go for +22 rear and 27-30 front.Ill take pics and show you anything over +20 will look terrible imo unless if you like poke.
<p>Pictures to GHO5T as promised a bit of poke as you can see.The rears are fine i reckon but the fronts have a bit too much poke but I can deal with that,just not flush
18 x9.5 +25F +20R rolled the back bur the front a bit of a guard roll still have a guard liner intact and rubbing only when cornering really hard.No problems on full lock.
Edited by B-rice
car is stock height
have a look at Voncina's post he has 10.5 though i think for rear
Edited by B-rice
which car?
34 gtt. Definitely going to run a 235/40 now as I'm realising the front is going to be a tricky fit.
I'll just have to put up with it until I convert to wide guards :yes:
Hey guys I need some help. I'm looking at getting work mister s1 19x10-46
Will I have trouble with fitment at all? Any help would be much appreciated cheers,
what are you fitting this onto? a truck?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
