has anyone fitted R33 GTR rims to an R34 GTR??? How would they sit in the gaurds???
Chasing some 17's so I can get an bit of tyre flex on the strip, can anyone suggest any 33gtr altenitives ???
Today I fitted my brand new enkei 18x9.5+12 with new advan 245/45/18, and on the left front wheel it scrapes with the rear of the arch when turning slowly? am I going have to get new tires with smaller profiles???
you could:
  • live with it
  • roll guards
  • camber
  • buy smaller profiled tyres
  • raise it
personally I'd buy some 235/40/18's
It only catches the side skirts front connection plate that comes into the wheel arch..... so annoying, I removed it becasue it was pulling it off tearing the plastic. Rarrrrrrh
the guard liner?
if you are hitting that it's a good idea to lip the guards just enough so they dont catch the tyre ever and tear the guard in half
(like blags lol)
the guard liner?
(like blags lol)
not the guard liner, on my r32 gtr the front of the side skirt actually comes around into the wheel arch and theres 2 screws,
Was thinking that but am unsure what + I need. Think it is around +20 to sit nicely in the guards of a 34 GTR
im so happy with these matte black rpfs, and for unsprung weight reasons aswell, there super light, only 7kgs!!!!! Forged BBS LMS which are forged are 12kgs in the same size!
bend and remove.... bend and remove ;)
pic?
I'm thinking of a set of matte black RPF01 in 18 x 9.5 +12 for the evo
Hey guys,
Was looking at getting some: Rota GRIDR 18 x 9.5, 5x114.3, +20 Absolute Green
To put on my '99 R34 GTT, It's currently lowered with stocks wheels still on it, doesn't have a camber kit as far as I'm aware. Anyone know how hard/easy it will be to get these to fit? Camber kit or rolling guards should be fine? Or just spend the money now and get a camber kit right away.
Cheers, Zac
Hey guys,
Cheers, Zac
Those rims will fit but you will need to roll guards n do some liner work.
Otherwise it all also depends on how much camber you do end up running as well as tyre size.
As far as camber kits go, they are only needed to reduce camber after lowering the car (essentially you can have heaps of camber from the stock arms if ur car is lowered, it is getting less than 1-1.5 degrees that is the problem once it is lowered). Obviously this isnt going to help the rims fitting as taking camber out puts the tyres closer to the wheel arch that is the limiting factor in actually fitting big rims with lower offset.
Any suggestion for tyre size? Its daily driven for now. So pretty much i'd just be looking at rolling the guards abit and giving it abit more camber, i love camber but don't want huge amounts as its daily driven,
stretch is against my religion. But a 235 should see you right.
Otherwise camber is also a bad thing in a street driven daily unless you dont mind paying the $ that it costs in how much quicker you chew ur tyres out because of said camber.. but around 1 degree on the rear should see the rims n tyres fitting as well as minimal tyre wear from it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
