has anyone fitted R33 GTR rims to an R34 GTR??? How would they sit in the gaurds???
Chasing some 17's so I can get an bit of tyre flex on the strip, can anyone suggest any 33gtr altenitives ???
Today I fitted my brand new enkei 18x9.5+12 with new advan 245/45/18, and on the left front wheel it scrapes with the rear of the arch when turning slowly? am I going have to get new tires with smaller profiles???
you could:
  • live with it
  • roll guards
  • camber
  • buy smaller profiled tyres
  • raise it
personally I'd buy some 235/40/18's
It only catches the side skirts front connection plate that comes into the wheel arch..... so annoying, I removed it becasue it was pulling it off tearing the plastic. Rarrrrrrh
the guard liner?
if you are hitting that it's a good idea to lip the guards just enough so they dont catch the tyre ever and tear the guard in half
(like blags lol)
the guard liner?
(like blags lol)
not the guard liner, on my r32 gtr the front of the side skirt actually comes around into the wheel arch and theres 2 screws,
Was thinking that but am unsure what + I need. Think it is around +20 to sit nicely in the guards of a 34 GTR
im so happy with these matte black rpfs, and for unsprung weight reasons aswell, there super light, only 7kgs!!!!! Forged BBS LMS which are forged are 12kgs in the same size!
bend and remove.... bend and remove ;)
pic?
I'm thinking of a set of matte black RPF01 in 18 x 9.5 +12 for the evo
Hey guys,
Was looking at getting some: Rota GRIDR 18 x 9.5, 5x114.3, +20 Absolute Green
To put on my '99 R34 GTT, It's currently lowered with stocks wheels still on it, doesn't have a camber kit as far as I'm aware. Anyone know how hard/easy it will be to get these to fit? Camber kit or rolling guards should be fine? Or just spend the money now and get a camber kit right away.
Cheers, Zac
Hey guys,
Cheers, Zac
Those rims will fit but you will need to roll guards n do some liner work.
Otherwise it all also depends on how much camber you do end up running as well as tyre size.
As far as camber kits go, they are only needed to reduce camber after lowering the car (essentially you can have heaps of camber from the stock arms if ur car is lowered, it is getting less than 1-1.5 degrees that is the problem once it is lowered). Obviously this isnt going to help the rims fitting as taking camber out puts the tyres closer to the wheel arch that is the limiting factor in actually fitting big rims with lower offset.
Any suggestion for tyre size? Its daily driven for now. So pretty much i'd just be looking at rolling the guards abit and giving it abit more camber, i love camber but don't want huge amounts as its daily driven,
stretch is against my religion. But a 235 should see you right.
Otherwise camber is also a bad thing in a street driven daily unless you dont mind paying the $ that it costs in how much quicker you chew ur tyres out because of said camber.. but around 1 degree on the rear should see the rims n tyres fitting as well as minimal tyre wear from it.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
