Im looking at some LMGT4 18 x 8.5 +20 and 18 x 9.5 +30 rears
looking at fitting the widest tyre possible without too much rubbing. Will the front have any poke or need camber at all to fit a 245 atleast.
Edited by B-rice
I had 245/40 on my old 17x9, my definition of stretch is different to yours of course.
265/35/18 on 18x10
Same size on 18x9
Each to their own
profiles are different... I said 235/45 as it's the most common size, you are talking about 235/40, which is more expensive and is always going to be more stretched as the sidewall is 5% shorter
also i'm not sure the relevance of a pic of a 265/35 on an 18x10
fwiw 235 on a 9 is well within the legal range too :)
no
I've had 245/40 and 245/45 on my 17x9 wheels and were stretched. 265/35 on my 18x10 are stretched, but my definition of stretch would be different to say, yours, I'm guessing. I didn't say anything about 235/40 :unsure: . The person asking didn't say anything about prices, plus 245/40/17 aren't as expensive these days. Yes 235/45/17 is cheaper as it's way more popular. That being said, would you want to run wider tyres that fit into the guards? I'm going to run 255/40/17 on the back of my R31 (17x9 wheels).
Picture was relevant to my "stretch" point (sidewall angle). 245 is slight stretch, 235 would be even more (that was my point).
Plus, 245/40 on a 17x9 +22 was made to fit on my mate's S14 with rolled guards, so that is a real world example (unless S14 guards have more clearance than R32).
hi everyone been reading for a while but not much on rotas
i have decided i would buy Rota-G force.
I want something that sits flush.dont mind if guard rolling is needed
dont want camber or anything like that n the car is still on stock springs
these are the set's that around what i wud like
18 x 9, +35
18 x 9, +27
18x9.5
what offset would look good ?
cheers :)
Sorry:/
Well some guy is selling rims he had on his 350z & they look really nice
I'm thinking of buying them.
18x10+ 12 rears
18x9.5+ 20 fronts
Rota is the brand
What sorts of problems will I come across to get them to fit?
Any help would be great:)
Cheers
will need to roll guards and camber
OR
roll and pull guards a little (flareing not reqired if you run like 245's on the 10's and 225/235's on the 9.5's)
OR
flare both guards to ensure the rims can fit and run the apropriate ammount of rubber
OR
run at landcruiser height
guard liners will have to be reomved to flare the fronts also if you want to go low
Can guard liners be retained if you just roll the fronts and not flare? Is there any benefit to doing so, or does it just lessen clearance?
they can however it's better to remove them as the bolts that hold them in are pretty good as catching tyres if the car is low
also clearace is an issue... my tyres would hit the metal above on occasion so liners would have been destroyed anyway...
also it's a good idea to jimmy up something to hold the cables out of the way in the right front arch
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
