according to my notes 9.5 +20 with 235 fronts and 265 rears ?
that's 18x9.5+25 with 235/40/18 all round
Heyas,
Keen on a set of DTM Racing P5 wheels.
I want them in 18x9 or 18x8.5 . They have +25 and +35 offset available.
They're for my 1998 R34 GT-T. Before i go and confirm the purchase it would be awesome if people had thoughts on whether i would have ANY problems or fitment issues with either.
Thanks in advance!
Hmmmm. seems like every set of wheel i want will take 2 months to arrive.. fuccckkkk
almost any wheel worth having you have to wait for, unless you want some ozzy tyres specials they are off the shelf ready complete with +54 offset.
try thinking of it this way.
the face of the rim remains static and the offset affects where the barrel sits
the exception is some rims like say drifteks for example where they make 1 cast then remove material from the back and boltholes dependant on offset requirements
to answer your q on types available, i'd suggest the motorsport section in drag n drift
  • Like 1
Yes they will fit, will probably need rolled guards. 265 are a bit large for a 9" rim. Go 235/40R18.
^265/35/18 on R34 GT-R wheel. Yep, 265 is way to big for 9" wide, even 235 is muffin. Get 185 wide tyres.
Note: italics is a way of displaying sarcasm.
I've got Lenso D1r 9J x 18s. Will it fit 265s? 34 GTT btw :thanks:
yes, however cant tell you if it will fot on the car without knowing the offset... as they are lenso's i'll assume +30ish and say they will fit fine
fkn lol
265 is big for a 9" wheel I doubt he needs a 265 for his application
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
