according to my notes 9.5 +20 with 235 fronts and 265 rears ?
that's 18x9.5+25 with 235/40/18 all round
Heyas,
Keen on a set of DTM Racing P5 wheels.
I want them in 18x9 or 18x8.5 . They have +25 and +35 offset available.
They're for my 1998 R34 GT-T. Before i go and confirm the purchase it would be awesome if people had thoughts on whether i would have ANY problems or fitment issues with either.
Thanks in advance!
Hmmmm. seems like every set of wheel i want will take 2 months to arrive.. fuccckkkk
almost any wheel worth having you have to wait for, unless you want some ozzy tyres specials they are off the shelf ready complete with +54 offset.
try thinking of it this way.
the face of the rim remains static and the offset affects where the barrel sits
the exception is some rims like say drifteks for example where they make 1 cast then remove material from the back and boltholes dependant on offset requirements
to answer your q on types available, i'd suggest the motorsport section in drag n drift
  • Like 1
Yes they will fit, will probably need rolled guards. 265 are a bit large for a 9" rim. Go 235/40R18.
^265/35/18 on R34 GT-R wheel. Yep, 265 is way to big for 9" wide, even 235 is muffin. Get 185 wide tyres.
Note: italics is a way of displaying sarcasm.
I've got Lenso D1r 9J x 18s. Will it fit 265s? 34 GTT btw :thanks:
yes, however cant tell you if it will fot on the car without knowing the offset... as they are lenso's i'll assume +30ish and say they will fit fine
fkn lol
265 is big for a 9" wheel I doubt he needs a 265 for his application
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
