hi guys im upgrading my 33 at the moment and im puting on a garret gt35r turbo and i was wondring if any one knows much about these turbos do they have mumch lage they told me its rated at 600 hp is this true i am hopeing to get around 300rwkw with apexi power fc big front mount 500 hp fule pump and fored pistons but he told me my stock injectors whould be able to handle it but if i put 555cc injectors on it what power am i looking at any help whold be greatful
p.s heres a pics of my car.
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/
Mate ill give you the best advice you'll find on this forum
search
this has been covered 100's of times.
GT30, 500-600hp is the way to go.
Search and hav e a read of all the threads and thier comments and then post if you have any further questions (which i doubt you will)
I've gone into depth as have many other's using the GT30.
GT35 is too big for a true fast streeter
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1529394
Your 33 is just a normal gtst isnt it? It looks like a s2 with some wild body kit and massively pumped guards. If it is a 25 then you will need the injectors for the power...the turbo will make it easy. Std internal limit is about 400rwhp. but i dont think anyone recommends going over 250-260 rwkws, So i would think pistons are a definete, maybe rods also. I know camshafts will help reduce the massive lag you will have with the turbo. If your only chasing the 300 rwkws a smaller turbo will do the trick and you wont lose out on so much response, unless your only after the high power and top end approach.
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1529418
I think a lot more people are recently posting these questions about the GT30 and 35 units because they are at such a good price. Maybe it would be worthwhile making one such thread that covers both these turbos sticky.
I think R31Nismoid is on the money suggesting the GT3040 unit. I think the .82 housing is the way to go for your set up. But if you don’t mind a bit of lag the GT35R is not so bad either. On an old post on this forum someone stated that a GT3040R with 1.06 housing performs the same at the GT35R with the .82 housing. Maybe do a search and have a read as there is a wealth of info on here.
Turbo specs: GT3040R comes in .63, .82, 1.06 housings and is rated between 500-600hp
GT35R also comes in .63, .82, 1.06 housings and is rated between 600-700hp
And dude, that is one wide body skyline!
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1534744
GT35/40r .82, 1.06 Is 700hp .63 is 600hp
GT 35/40r 700hp roller bearing turbos for $1799 BRAND NEW in the box with 12 months warrenty.
For ur skyline .82 would be fine 700hp 1
where could i pick one up for 1799?
got a link?
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1535247
GARRETT GT35/40 BRAND NEW x 3 - $1500 XR6Turbos
http://www.calaisturbo.com.au/showthread.php?t=50543
$1799 BRAND NEW garret 35/40r
http://www.calaisturbo.com.au/showthread.php?t=44231
not sureif u have to sign up, its a VLT website tey got so much stuff for sale
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1536582
got a link?
Lets support our sponsors/donators contact Tarek from RACESPEC; details below.
Mob: +61 401 313 163
Fax: +61 8 8359 7953
Web: www.racespec.com.au
[email protected]
RACESPEC do these units for $1775 delivered.
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1536686
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
