A stock out of the factory Type M weighs 1290kg unladen. Add to that the weight of fuel (60l tank) and optional bits n pieces and it'll get heavier. Non Type M GTSt's were 1260kg.
And for the love of god stop calling it a M Spec... the only M Spec Skyline Nissan made in the 90's was an R34 GTR.
RB25DET's weren't available in R32 GTSt's. RB25DE (non turbo) engines featured in the R32 GTS25 though.
An RB20DET engine makes 158.13 kw at 6400 rpm and 264.78 Nm at 3200 rpm.
Greetings All.
Thanks funkymonkey! Sorry i called it a m-spec...lol...
Im just doing research on it all at the moment, thats why i kinda need to know what sorta power + torque the RB25DET makes...infact...what about the RB25DE??
Cheers,
--Tonba
My man :)
I swear sometimes it seems Shan and I have the same brain but I'm white and he's bleck
:lol:
If everyone on SAU could *get it right* and call R32/33's 'Type M's' it'd make us sound more like proper Skyline enthusiasts... /rant (so says a Silvia owner)
You see a lot of different figures out there for the R32 weight.
got a bit heavier in the new ones..
mine weighs 1270kg unloaded (non typem auto).. but if you ditch the spare (15kg.. yes 15kg), and get a gtr bonnet.. thats an easy 25kg saved..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
