dondesoto Posted August 22, 2005 Share Posted August 22, 2005 (edited) Dont know if anybody has done this on an rb25de . I now have most of the parts to make up a 2 x tb and 2 x afm setup . just waiting on a s/h manifold to arrive . Am going to cut off the side off the plenum where the single TB is , then weld on a 12 mm plate and mount the 2 x TBs on it . Then install seperate tubes to each of the AFMs . Electrically hooking up thru the apexi safc 2 which has provision for 2 x AFMs then converts signals back to a single feed signal to the ecu . Will keep you posted on progress . presently i,m running a 68 mm tb , and its on a rb30de . Edited August 22, 2005 by dondesoto Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/ Share on other sites More sharing options...
Beer Baron Posted August 22, 2005 Share Posted August 22, 2005 why would you want to do that? Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1537068 Share on other sites More sharing options...
NA_R33 Posted August 22, 2005 Share Posted August 22, 2005 less restriction, rb twin cam heads flow very very standard, what holds them up as with any NA engine is the ability to breath through the exhaust and intake system. Very interested to see how this goes.. keep us posted Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1537204 Share on other sites More sharing options...
Eug Posted August 22, 2005 Share Posted August 22, 2005 Sounds like a very good idea Don, are you going to do a dyno run before all this (would be keen to see your RB30DE results) as well as the changes the twin throttle bodies would make. Eug Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1538245 Share on other sites More sharing options...
dondesoto Posted August 22, 2005 Author Share Posted August 22, 2005 (edited) Sounds like a very good idea Don, are you going to do a dyno run before all this (would be keen to see your RB30DE results) as well as the changes the twin throttle bodies would make.Eug <{POST_SNAPBACK}> no wont be doing a dyno before , i use the test and tune nights at the drags to see how its running ( best 14.7 @ 93 mph ) . but i may put it on the dyno to get it fine tuned after i do the mods . also waiting on an adjustable exhaust cam gear to fit as well , and still got to fit the 4.11 locked diff . Edited August 22, 2005 by dondesoto Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1539128 Share on other sites More sharing options...
rob82 Posted August 26, 2005 Share Posted August 26, 2005 Have seen twin throttle bodies on a VL 3.0L with medium cams made 141rwkws. Thats almost double the power of standard. Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1548013 Share on other sites More sharing options...
dondesoto Posted September 3, 2005 Author Share Posted September 3, 2005 progress on the manifold , flanges for throttle bodies to be made . using rb25de/t throttle bodies Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1561420 Share on other sites More sharing options...
dondesoto Posted September 26, 2005 Author Share Posted September 26, 2005 more progress pics on 2 x throttle body manifold Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1607943 Share on other sites More sharing options...
Eug Posted September 26, 2005 Share Posted September 26, 2005 nice progress Don! you doing all this yourself? Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1607950 Share on other sites More sharing options...
dondesoto Posted September 26, 2005 Author Share Posted September 26, 2005 nice progress Don!you doing all this yourself? <{POST_SNAPBACK}> yep all my own work , aluminium welded all bits then filled with devcon aluminium putty and smoothed . Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1607992 Share on other sites More sharing options...
NA_R33 Posted September 27, 2005 Share Posted September 27, 2005 15 3 phase migs.... 1 tig.... and not one can do alloy..... stupid workshop!! i ennvy you don.. Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1608496 Share on other sites More sharing options...
Nosmo Posted October 20, 2005 Share Posted October 20, 2005 What are you doing with your old 68mm throttle body and plenum? Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1654155 Share on other sites More sharing options...
dondesoto Posted October 28, 2005 Author Share Posted October 28, 2005 What are you doing with your old 68mm throttle body and plenum? <{POST_SNAPBACK}> well i will see how this setup will work 1st. Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1672763 Share on other sites More sharing options...
dondesoto Posted October 28, 2005 Author Share Posted October 28, 2005 (edited) seems i cant run 2 x afm s , so am going to make up a Y piece from the 2 x t/b and just use the 1 x afm Edited October 28, 2005 by dondesoto Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1672782 Share on other sites More sharing options...
Eug Posted October 28, 2005 Share Posted October 28, 2005 any reason for that Don? safc? Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1674421 Share on other sites More sharing options...
dondesoto Posted October 28, 2005 Author Share Posted October 28, 2005 any reason for that Don? safc? <{POST_SNAPBACK}> well this is the way i understand it . with 2 x afm the output signals of the afms would be 1/2 that of just 1 x afm the safc can accept 2 x input signals , then sends out 1 signal which is just an average of the 2 x inputs not adds them together .. so i still end up with just half the normal signal . the ecu would send the ammount of fuel to suit that signal , not enough . Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1675059 Share on other sites More sharing options...
dontfeelcold Posted October 29, 2005 Share Posted October 29, 2005 well this is the way i understand it .with 2 x afm the output signals of the afms would be 1/2 that of just 1 x afm the safc can accept 2 x input signals , then sends out 1 signal which is just an average of the 2 x inputs not adds them together .. so i still end up with just half the normal signal . the ecu would send the ammount of fuel to suit that signal , not enough . <{POST_SNAPBACK}> sounds logical. Did you paint the the plenum with something? Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1675200 Share on other sites More sharing options...
dondesoto Posted October 29, 2005 Author Share Posted October 29, 2005 sounds logical. Did you paint the the plenum with something? <{POST_SNAPBACK}> yep painted it silver cold galvanising paint . not too shiny or tackey like chrome paint and lasts longer. Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1675510 Share on other sites More sharing options...
Eug Posted October 29, 2005 Share Posted October 29, 2005 well this is the way i understand it .with 2 x afm the output signals of the afms would be 1/2 that of just 1 x afm the safc can accept 2 x input signals , then sends out 1 signal which is just an average of the 2 x inputs not adds them together .. so i still end up with just half the normal signal . the ecu would send the ammount of fuel to suit that signal , not enough . <{POST_SNAPBACK}> i see... that changes things a bit. are you opting for a larger diametre single pipe before the Y piece? what type of afm are you intending to use? is this the case for gtr's? can anyone else shed some light on this. its great to see you doing something different don, keep us posted! Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1676078 Share on other sites More sharing options...
BADR33 Posted October 30, 2005 Share Posted October 30, 2005 hey. for the SAFC cant you tune it to run +or- 50% less/more fuel? so there for you should be able to tune it to run with more fuel to cater for the increased airflow? just hook it up to one afm and run 50% more fuel? i can see the logical part of the thinkin that you will end up with half the signal of 1 AFM. there must be away around it either using resistors or somthing similar. otherwise just go for a aftermarket computer. very nice work tho. Link to comment https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/#findComment-1677800 Share on other sites More sharing options...
