Dont know if anybody has done this on an rb25de . I now have most of the parts to make up a 2 x tb and 2 x afm setup . just waiting on a s/h manifold to arrive . Am going to cut off the side off the plenum where the single TB is , then weld on a 12 mm plate and mount the 2 x TBs on it . Then install seperate tubes to each of the AFMs . Electrically hooking up thru the apexi safc 2 which has provision for 2 x AFMs then converts signals back to a single feed signal to the ecu . Will keep you posted on progress .
presently i,m running a 68 mm tb , and its on a rb30de .
Edited by dondesoto
https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/
  • Replies 72
Posted Images
less restriction, rb twin cam heads flow very very standard, what holds them up as with any NA engine is the ability to breath through the exhaust and intake system.
Very interested to see how this goes.. keep us posted
Sounds like a very good idea Don, are you going to do a dyno run before all this (would be keen to see your RB30DE results) as well as the changes the twin throttle bodies would make.
Eug
no wont be doing a dyno before , i use the test and tune nights at the drags to see how its running ( best 14.7 @ 93 mph ) . but i may put it on the dyno to get it fine tuned after i do the mods .
also waiting on an adjustable exhaust cam gear to fit as well , and still got to fit the 4.11 locked diff .
Edited by dondesoto
  • 4 weeks later...
  • 4 weeks later...
any reason for that Don? safc?
well this is the way i understand it .
with 2 x afm the output signals of the afms would be 1/2 that of just 1 x afm
the safc can accept 2 x input signals , then sends out 1 signal which is just an average of the 2 x inputs not adds them together .. so i still end up with just half the normal signal . the ecu would send the ammount of fuel to suit that signal , not enough .
sounds logical.
Did you paint the the plenum with something?
i see... that changes things a bit. are you opting for a larger diametre single pipe before the Y piece? what type of afm are you intending to use?
is this the case for gtr's? can anyone else shed some light on this.
its great to see you doing something different don, keep us posted!
hey. for the SAFC cant you tune it to run +or- 50% less/more fuel? so there for you should be able to tune it to run with more fuel to cater for the increased airflow? just hook it up to one afm and run 50% more fuel?
i can see the logical part of the thinkin that you will end up with half the signal of 1 AFM. there must be away around it either using resistors or somthing similar. otherwise just go for a aftermarket computer.
very nice work tho.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
