Dont know if anybody has done this on an rb25de . I now have most of the parts to make up a 2 x tb and 2 x afm setup . just waiting on a s/h manifold to arrive . Am going to cut off the side off the plenum where the single TB is , then weld on a 12 mm plate and mount the 2 x TBs on it . Then install seperate tubes to each of the AFMs . Electrically hooking up thru the apexi safc 2 which has provision for 2 x AFMs then converts signals back to a single feed signal to the ecu . Will keep you posted on progress .
presently i,m running a 68 mm tb , and its on a rb30de .
Edited by dondesoto
https://www.sau.com.au/forums/topic/84884-2-x-afm-and-2-x-tb/
  • Replies 72
Posted Images
less restriction, rb twin cam heads flow very very standard, what holds them up as with any NA engine is the ability to breath through the exhaust and intake system.
Very interested to see how this goes.. keep us posted
Sounds like a very good idea Don, are you going to do a dyno run before all this (would be keen to see your RB30DE results) as well as the changes the twin throttle bodies would make.
Eug
no wont be doing a dyno before , i use the test and tune nights at the drags to see how its running ( best 14.7 @ 93 mph ) . but i may put it on the dyno to get it fine tuned after i do the mods .
also waiting on an adjustable exhaust cam gear to fit as well , and still got to fit the 4.11 locked diff .
Edited by dondesoto
  • 4 weeks later...
  • 4 weeks later...
any reason for that Don? safc?
well this is the way i understand it .
with 2 x afm the output signals of the afms would be 1/2 that of just 1 x afm
the safc can accept 2 x input signals , then sends out 1 signal which is just an average of the 2 x inputs not adds them together .. so i still end up with just half the normal signal . the ecu would send the ammount of fuel to suit that signal , not enough .
sounds logical.
Did you paint the the plenum with something?
i see... that changes things a bit. are you opting for a larger diametre single pipe before the Y piece? what type of afm are you intending to use?
is this the case for gtr's? can anyone else shed some light on this.
its great to see you doing something different don, keep us posted!
hey. for the SAFC cant you tune it to run +or- 50% less/more fuel? so there for you should be able to tune it to run with more fuel to cater for the increased airflow? just hook it up to one afm and run 50% more fuel?
i can see the logical part of the thinkin that you will end up with half the signal of 1 AFM. there must be away around it either using resistors or somthing similar. otherwise just go for a aftermarket computer.
very nice work tho.
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
