I orded a cooler kit off http://www.slidingperformance.com/
The pic of it all assembeled is the one off the website, the otther fotos are ones i took, and some people added speech bubles.
Im very impressed, delivery was quick, no complaints. Ill keep posting how i go tonight cutting up my front bar and making hole fdor the return pipe.
:lol:
Edited by sproosy
https://www.sau.com.au/forums/topic/84956-got-my-cooler-kit-today/
got teh pics in. teh cooler kit was $629 pipes and hybrid style copy cooler delivered.
i soughta f**ked it up a bit and mounted it slightly crooked, and in the fotos you can see my nicely scratched bar. But there is always tomorow to to fix up my slightly crooked cooler.
Over all it took me from about 11am until 5pm to pipe it up.
Last night i sat around with the dremel and cut the bar so the cooler could fit in. That took about 1 hour. And also 30 mins to mount the cooler.
Im sure lots of other people out there could do it quicker, but im a suit (white collar) and im not too good with this stuff sometimes as you can see by the crooked cooler. \\Next i have to do a dyno run with a little more boost and see what i get. From what i have read im hoping for 145 - 155rwkw.
Ill keep this thread updated.
Edited by sproosy
Awesome, trurly awesome.
I bought a Pizza last night, it was tasty - TASTY!
I cant get pizza's atm but if i can ship one in from Japan real quick you wanna buy one? :lol: rofl1yv.gif
Cheers Ryan
Edited by Slide
Well how long would it take you to do up 4 bolts? It didnt get all "wonked" until i connected the pipes up and the bar cause i f**ked up and knocked it and bent it when i lent agaisnt it. My bad!
Hence why i said "there is always tomorow"
Edited by sproosy
Well how long would it take you to up 4 bolts? It didnt get all "wonked" until i connected the pipes up and the bar.
Hence why i said "there is always  tomrow"
took me close to an hour to mount mine, to align the lengh in middle and the depth and to punch a groove to drill and so forth...
point is i would never be assed to take it off and do it again.
how did u knock it out of place?
Edited by silver gts-t
i went to get up and i put my hand on it to pull myself up and i think thats when i did it. I check it all up and measured it and all that shit last night and it all looked good. i cant think of anything elses that would of made it move.
its up as high as it can go before i have to cut into the chasis which im not prepared to do. Ive got no problems with driveways and the like, the only thing that would be an issue would be the concrete blocks they put in parking spots so you dont drive too far forward, hence the scracthes already on the front bar.
Thanks for your concern.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
