//updated 5 January 2006.
FYI, these have been amalgamated across all the series (R32-R34 mainly)..some models were not available in a particular colour (eg JW0 was only on some Nur spec Skylines).
326 - Crystal White
732 - Black Pearl Metallic
AH3 - Red Pearl Metallic
AN0 - Super Clear Red
AR1 - Super Clear Red II
AR2 - Active Red
BJ0 - Light Blue Metallic*
BL0 - Greyish Blue Pearl
BN6 - Deep Marine Blue
BP9 - Dark Blue Pearl
BT2 - Champion Blue (the colour of the LM spec GTR 33s)
DN0 - Green Metallic
EV1 - Lightning Yellow
EY0 - Silica Breeze
GV1 - Black Pearl
JW0 - Millenium Jade
KG1 - Jet Silver Metallic
KH2 - Gunmetal Grey Metallic
KH3 - Black
KL0 - Spark Silver Metallic
KN6 - Dark Grey
KP4 - Sonic Silver
KR4 - Sonic Silver
KV2 - Athlete Silver
LP2 - Midnight Purple
LV4 - Midnight Purple II
LX0 - Midnight Purple III
QM1 - Cloud White
QT1 - White Pearl
QX1 - White Pearl
TG0 - Light Grey Metallic*
TH1 - Dark Blue Pearl
TV2 - Bayside Blue
WV2 - Sparkling Silver
The attached PDF file contains all known colours used by Nissan. It is written in katakana. If your colour isn't listed, check the pdf because it's most likely there.
To come: DR30, R31, etc colour codes.
CLRNISSAN.pdf
https://www.sau.com.au/forums/topic/84965-skyline-paint-codes/
  • Replies 74
I think you've got it wrong FAT32. 'RC43' on the engine plate usually refers to the axle (4.3:1 final drive)
Cheers razor :)
I have no idea what any of that chicken scratch on the data plate means :(
  • 3 months later...
  • 3 weeks later...
They were on different Skylines eg LV2 was specific to the 33 GTR, LV4 and LX0 were for different runs on the 34 series.
does it still look identical if you were to put the different models beside each other or are ther subtle little differences??
LP2 - Midnight Purple - single pearl paint
LV4 - Midnight Purple II - triple pearl paint
LX0 - Midnight Purple III - chameleon paint
different mixes of paint that made different effects on the purple.
Thanks for the picture post. I think it would be great if we could get people to post an attached picture of their car (which best shows an accurate representation of the color its painted) while mentioning what paint code their car is. This would be a great help to the community when repainting and deciding on a color :-)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
