4th Gear
Guest EVL-R33
hey ppl, recently when changin to 4th gear from high revs from either 2nd or 3rd my 4th gear keeps crunching for no reason i know its something wrong but i just wanna see if anyone would know the problem or experience it b4,
At the start it would crunch really hard and not go in, now after 2 weeks it goes in but still crunchs softly, it needs fixing a.s.a.p i just got back from my holiday and its time to get it done...
thank you..
https://www.sau.com.au/forums/topic/8497-4th-gear/
Mine does it on 4th as well. I just figured the synchro was on it's way out and am living with it. If you're just cruising then try and match the revs to the gear when you're changing up into 4th. If you don't know what i mean, try pulling the shifter 'against' the gate into 4th when you change up with your foot on the clutch instead of just forcing it in. You'll find that as the revs of the engine match the revs of the flywheel, it will just go in by itself.
I don't know if this makes any sense at all but I hope it helps. It's just like riding a motorbike. I hardly ever use the clutch on up-changes. All I do is put a little bit of pressure on the shifter with my toe and back off the revs slightly so it clicks into gear.
Good Luck
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-123715
There was a similar thread a while back on SDU i think and from memory they suggested a good oil change with a stick of Nulon GE70 (i think that's what it was), drive nicely for 500kms then see if it still crunches when giving it a bit of welly.
I haven't tried this so dunno if it makes a difference.
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-124102
The shockproof oils will definately help, they should lessen any additional strain on the synchros and reduce the crunching noise. It is not however going to fix the problem, therefore I think that saving up to replace the synchro might be a good idea. At the same time get them to check the whole box, if one synchro is going then the box may be on it's way out.
See'ya :burnout:
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-124195
The problem with the syncro's is sometimes an issue with the oil being too slippery and not slowing the shaft down before changing.
Nissan did an upgrade to the GTR boxes which had the same problem but cost about 2K for parts alone.
I have solved the problem on 3 x Nissan boxes so far for about $100-$120 by using Redline Lightweight Shockproof oil ( blue smurf ).
Is amazing stuff and ask Micko who will vouch how well it is still going.
Ken
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-124242
  • 3 weeks later...
I got it from CRD in silverwater. Bloody expensive @ about $100, but cheaper than pulling out the gearbox and reconditioning it :;
I don't think its a permanent fix, the gearbox still baulks at a quick change, but the crunching is gone and the motion is smoother. Thumbs up from me.
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-143625
Originally posted by benm
Dumb question but where and how do u replace gearbox oil ? Anyone got any pics of exactly where it goes ?
On the bottom ot the box there's a plug, undo that to drain then plug back up. On the drivers side of the box, there's another plug. Open and fill up until it starts pouring out a little.
Duncan, you bum!:)
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-144976
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
