10/01/2003 Cruise pic post & chat thread
  • Replies 208
Originally posted by Gardo
I was in a group of skylines from the frankston stop untill close to arthurs seat....Who were you guys?? we were stuck behind some guy towing a boat on a 1 lane road for a bit....and we stopped at BP. That was quiet a nice cruise up...I was astonished at the speed of a purple GTR that was with us...O M G, respect!
we were in the black R32 GTR in that group...
Originally posted by skyline33 Ula32's car was a monster, Ula32 you know why?? (R34 ring a bell)
and
Originally posted by uLa32
as for the r34 i think he got too much wheelspin... i took of 'normally' at 6 grand :D
I am still perfecting my take-offs guys!
I was only @ 3-4 grand with t/c switched ON!
No wheelspin, just bogged down for a second or two then I started...do'h...finally...
Originally posted by nismoR34
and
mate just kidding mate, it was a great cruise definetly.
hehe oh that was ur R34 :wave: i was in the black 32 GTST in front of u at those lights leaving albert park who took a pic out the front window of the line :D. then pulled over so u guys could go past cause i had no idea where the hell we were going.
i was taking pics out the drivers window while driving down nepean hwy down chelsea area if thats what you were talking about
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
