RB20DET, Stock turbo 15psi 164rwkw
City: 470km's per ~50litres. That is until the red light first shows.
Open Road: Not sure have never taken it on a full tank.
WOT: Booting it the RB20DET would drop fuel economy to low 400's per tank.
Driving style didn't appear to make much difference to fuel economy.
RB30DET - Stock rb20det turbo 176rwkw 9psi.
City: 450km's per 50litres.
Open Road: Again. Not sure.
WOT: Booting it the RB30DET drops to 380km's per tank.
I'm scared to start swapping out the stock injectors incase fuel economy goes to the sh*t. :D
Mind you Bl4ck32 has 550cc rx7 injectors thats all been tuned up, his rb30det in his r32 tends to get slightly better fuel economy than mine.
Edited by Cubes
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1541740
ive found a trend in my car. it's basically always KMs/10 + 10 = Litres of fuel
so 350kms = 45L filled up
400km = 50L filled up ... and so on
my 33's usage was similar
so far ive only had one tank which was used for pure thrashing and i did about 250km in 55Ls :D
freeway driving is typically a lot better than the formula above.. the other day after filling up, i drove 130kms. then i pulled over and filled it up again, and i only put in 16Ls..
edit: i just realised that the above does not apply to u as i have an rb25det in my 32.. lol sorry.
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1557199
Hiya,
I've got an R32 GTS-t manual and I get roughly 380-400km out of the tank of regular city/suburban driving.
just did a drive up to Sydney and back a few weeks ago before that dreaded fuel increase and estimated with general cruising averaging 115-120km/h I could get around 600km to the tank.
Mind you though the car's running an aftermarket replacement ECU and it doesn't run an airflow metre anymore so I was expecting it to drink more than that... :)
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1563157
  • 2 months later...
ok i should mention this isnt untill the light comes up...
probably a touch above E
Im with you silver gtst..... i like to fill up before the sludge in the bottom of my tank strts clogging up the injectors!!!!!
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1757525
Fuel tanks get a build up of crap over the years. A friend of mine had a vl turbo that used to run really rough whenever the fuel gauge went below 1/4. Thats the worst I've ever seen.
You could fix it by taking the fuel tank out and cleaning it out, but that is just sooooo much effort, much easier to just keep a nice amount of fuel in there. :)
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1762131
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
