Hi Gary,
Can you please advise the final cost of the complete kit sent to Brisbane please.
I am chasing the entire kit, need to replace my super-stiff and annoying Tein coilers front and rear the rest of the suspension is standard.
Will i need the bump stops?
Kind regards
Simon
Edited by Simonster
Hi Gary,
Kind regards
Simon
PM sent
:D cheers :D
shocks went in today and work great!!
car rides nicely and very smooth still - onyl slightly harder than stock, but definately handles better and sits 24mm lower than stock
for everyone's reference, i used the bilstean shocks on stock springs dropped down 3 circlip grooves...
i might get the rear guards rolled for precaution given that i'm running 9" rears with +40 offset
a question for everyone though:
when i picked the car up, they said that something else was also worn out. they pointed it out on the car, but i don't know what its called. it connects from the lower control arm to something under the engine. looks like a rod with a ball-shaped thing on the end
can anyone enlighten me as to what it is and whether or not it actually might need replacing?
oh, and i had the suspension fitted at Vitanza Tyres in Fortitude Valley, Brisbane. Highly recommended for tyres and suspension
cheers,
Warren
possible radius rod bushing but im really not too sure what ur describing by ur description. Take a pic if u can.
yeh thats what i reckon it is too, also know as caster rods and tension rods.
yeha from what ive been told they prevent movement of the control arm under accel and braking in order to prevent castor and camber changes in the steering geometry...But as i sed im unsure whether this is the part he means...need a pic to be 100% sure
ok so this is a picture of what is supposedly worn on my car..
it has some oil/moisture around it, but not as bad as in this picture
so my questions are:
- what is it called?
- are they on front and rear or just front?
- where can i get a replacement?
would appreciate any help!
Warren
ok i have done some more research..
i think they are castor rod bushes...
and i understand that new ones can be had through the group buy, is that correct SK?
do those have the same functionality as the stock ones?
cheers,
Warren
Theyre caster rod/radius rod bushes.
i just had mine replaced coz they were completely cracked
the group buy has them, KCA331.
otherwise theyre about $360 from nissan i think
the stock ones arent adjustable whereas the whiteline are.
I'd say thats the only difference....probably last longer too
Anyone considering an R32GTST kit should move quickly as there is only 1 set of R32GTST rear shocks left in stock. No production is currently scheduled, so it may be many months before Bilstein do another production run.
There is no alternative shock available, R33 and R34 rear shocks are too long and R32GTR rear shocks have the fork at the bottom not the bush.
:wub: cheers :yes:
There is only 1 (yes ONE) set of R32GTST rear Bilsteins left in stock at Bilstein. There are no shipments planned and there is no production schedule. So when this set is sold I will close the Group Buy.
:D cheers :wave:
hi sk
will you be able to ship a set of front and rear shocks to Cape Town; South Africa? what will shipping cost be?
Thanks
Shipping will be more than the shocks cost, try the SA Bilstein agent.
:P cheers :D
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
