A handy arrangement last week has led to Golgo sporting some new footwear. Replacing the stalwart TE37s are a set of Work Emotion CR Kai rims - in bronze, of course.
I think they look great!
Is a slightly darker bronze than the Volks - but it suits the purple perfectly.
Still 18x9.5" - the offset is slightly different, so they don't sit out quite as wide as the TEs did... but the difference is negligable.
They have stickers which will be applied in due course - as we all know how much I like stickers :D
Details here:
http://www.work-wheels.co.jp/wheels/index/.../emt-k1p-2.html
The Volks have gone to a very deserving home - so stay tuned to see them on their new owner in the coming weeks. Will look hot :P
James
https://www.sau.com.au/forums/topic/86080-rimjob/
  • Replies 72
Ah Shan, that's the door.
The a-pillar is the bit the windscreen is attached to :D
But yes... the stickers are my next project.
Time they came off I'm afraid :P
BTW: Technically, since I still have the Rays wheel nuts - it's OK to leave them though :P
https://www.sau.com.au/forums/topic/86080-rimjob/#findComment-1557604
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
