Hey guys,
i thought for now so that we can kinda get to know everyone and put some faces to the names or at least some locations around vic we could post them all here. There also seems to be a lot of new guys coming thru so thought this could be handy.
Try and keep it to one post per person... if u find someone in ur area or have any questions for that person then please just use PM so we can make this sticky and easy to sort thru... rather than sorting thru hundreds of "hey u live near me! what u drive?" "any pics? i think ive seen u around" etc etc
I'll start off.
nick: inark/nark
Car: A31 Nissan Cefiro (RB26 inside)
Email: [email protected]
ICQ: its in the profile
Heres a pic :)
pics of my cars here
R32 Coupe - SOLD
RB26 Cefiro - SOLD
JZZ30 Soarer - SOLD
R32 Sedan - Current
https://www.sau.com.au/forums/topic/8644-sau-vic-forum-goers/
  • Replies 186
hey guys.....this is my first post...figured what better place to put it than here.
nick: (B1) MR_fanny
car: R33 GTS-T
email: in profile
icq: in profile
wouldnt have a clue how to post up a pic .....maybe its for the better...haha....these should keep you busy
:boobies2::boobies2::boobies2::boobies2::boobies2::boobies2:
acsplit
Car: 1988 R31 Silhouette GTS # 47 of 200
MSN : as per above
Car pic
My r31 GTS
Pic of me i need to get it off funkey monkey it was from the r31 supercruise
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
