Yes or No?
59 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I've still got mine. There really isn't much point in taking it out unless you wanna hide a set of fuel pumps in your boot.
You'd be wiser having it in there just incase you find yourself with a flat even though I wouldn't trust my life to them
. plus worse case scenario is it actually acts as a good way to absorb a crash in the rear-end if some dero gets distracted by how nice your car is and forgets to hit the brakes.
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1563188
I'd like to remove mine but I've had to use it once.
Although without a toolkit (I was lucky and had one on me at the time) there's no point me having it there. I might remove it :P
Doesn't the R33 have the little toolkit behind the panel on the left of the boot ala R32?
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1564163
i dont have one in my gtr
it didnt come with a jack, and i figure if i cant jack the car up, i cant put a spare tire on, so no point having the spare either
you can buy those cans of stuff you spray into the tyre if you get a flat, that or dad can come rescue me
Edited by lang
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1565140
Yeah, the space saver is in there, although it wouldn't have helped without the tool kit that is supposed to be in there. Only the jack was there, no wheelbrace or jack handle. Took it back to the importer and he checked every Skyline he had and none had theirs either!! Seems they are a hot item in Japan????
https://www.sau.com.au/forums/topic/86475-yes-or-no/#findComment-1570508
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
