Just Jap Racing is pleased to offer our customers this fantastic deal on our latest Bride Style Reclinable Racing Seats.
These seats are manufactured using quality material and feature a strong steel frame with lever reclining mechanism and are all ADR approved.
Each seat comes with universal rails which can easily be adapted to suit your car with minor modifications.
Available in Red or Black Durable Mesh Fabric.
Place your order with Just Jap, a trusted, respected and established Sydney business with huge factory showroom and after sales support available and enjoy the peace of mind of knowing that there is:
1. No deposit required
2. No minimum order
3. Easy online payment options
4. No surprises
AVAILABLE NOW FOR $449.00 PER PAIR
HOW CAN YOU PLACE YOUR ORDER?
The answer is simple!
Purchase online now via our massive new website at http://www.justjap.com for fast Australia-wide delivery.
With Australia's biggest range of High Performance Japanese Parts all under one roof, and all available online, purchasing your tuning parts online couldn't be easier!
Please contact our sales team if you have any questions, or reply here.
  • Replies 175
Posted Images
G'day how much for 1 black one? I might get one for the passenger side. Do the seats have a bracket for the seat belt "clicker"?
Edited by LANFOH
Hi LANFOH - If you are after one seat only they are $225 each, or $350 for the pair and include universal rails.
The rails need to be modified and adapted to your existing seat rails so of course there will be a facility for your seat belt lock-in.
Regards,
Steve
How many adjustment points are there on these seats?  Just reclining or is there panning and height control as well?
Hi mate, they arent height adjustable
Cheers,
Steve
Hi JL,
The seats include universal rails which need to be modified and adapted to your existing seat rails. Some minor welding may be required and we recommend having the seats fitted by a knowledgable workshop.
How much stock will you have available? And are you going to tell us when they actually arrive... trying to budget for a few items at the moment :)
How much stock will you have available? And are you going to tell us when they actually arrive...  trying to budget for a few items at the moment :huh:
We have these and loads more coming, and of course I will let all of you know when they land! :blink:
Cheers,
Steve
Any idea of the weight of these seats?
Offhand no, they havent arrived in the country yet so I am unable to weigh them at the moment
Steve
Steve,
Do these fit fat assed people or is it skinny size only?
Thats a matter of opinion :) We will get some measurements of the seats dimensions when they arrived and post the details :blink:
Steve
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
