Hi guys,
Just wondering how much I should be paying to get some brackets fabricated to suit using the R34 GT-T calipers on my R31 import struts. Everything is removed and ready to go.
Several of the larger racing fabricator mobs who shall not be named have sort of scoffed at me a little, and then told me they're too busy and to come back in a month, or quoted some stupidly high number and seem rather uninterested in helping.
Perhaps you guys could help.
Thanks,
Mark
Edited by MarkE
They should bolt straight up to the R31 import Struts, if the caliper Mounting for the R34 caliper is 100MM it should fit, i know that R32/Z32 Calipers bolt straight onto the Front HR31 Struts....
this is what i thought!
Have you tried bolting them on?
just a suggestion, but why not just sell the 34 calipers and get the brembo's that go with the discs, would be the right offset from the get go. or fit the 310mm rotors from the GTT and be happy.
but then theres the price tag on the brembo's.... :huh:
Note the caliper will sit 28mm out more towards the rim.
No they wont :)
324 - 296mm is 28mm sure. But thats the difference in daimeter. You only offset the caliper to suit the radius. So only moves them out 14mm. And since you are only moving them out 14mm, you cant use the same centre holes so need bracket like yours which will also roll the caliper around further so that it can be bolted back in place. So the caliper will now be mounted closer to the 9 o'clock position, where as std they are more up around the 10 o'clock position of the rotor.
No they wont :D
I was wondering that!!
Thats what u told me when i asked u ages ago about offset as i have very little clearance between rim and caliper at the moment!!! :D
If it will only sit 14mm out then they should be sweet with my current rims
not to hijack the thread or anything but while we're on the topic of caliper offsets, anyone know what the thickness of the outer side of the caliper is? ie from outer disc face to outer caliper face? need to know wether my rims will hit when i put mine on!
back on topic!
Cheers
:D
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
