good that you asked, because people use a high pressure water cleaner and then ask why there car is running like crap :)
hahaha, just like a guy I know got into his Impul's engine bay with a high pressure hose, and then found his windscreen wipers to run by themselves. :D
Driving through the middle of the city on a warm night with your wipers going isn't the greatest look.
Haha, after a very thorough wash of my car one night I found the back windscreen wiper going by itself. I just unplugged the motor and once it had dried out plugged it back in and all was sweet.
Anyway on-topic, the best way to clean the engine bay is with microfibre lint free cloths and lots of patience... A little degreaser used discreetely is useful as well.
hahahaha just the other night i was driving into the carwash place when i saw this guy washing his engine bay with a high pressure hose. once he tried to drive off it was running really rough and he didnt have a clue why..
its quality stuff to watch
This thread bring a question up for me, what if you have a vented bonnet and its raining heavily, Water could get anywhere in the engine bay, wouldn't it be similar to washing the engine bay without covering anything?
Possibly. It would depend on the vent angle and size. If you were driving at the time its obviously far less likely given most vents face towards the back of the car, and any water that did make it in would probably evaporate when it hit the engine.
I put a fairly liberal amount of water on my engine last weekend and it was fine. Didnt blast the top of the motor too much and obviously kept direct pressure away from the fusebox and pod filter...was all good.
The biggest problem always seems to be getting the coil packs and spark plugs wet (judging by the number of "OMG!!!111 My car won't start post washing" posts).  Maybe cover sensentive areas with some plastic.
LOLOLOLOL thats what my friend (who has owned his skyline for 8years) did to my car which made me miss the show and shine remember? :P Bastards.. if only this thread was made back then
On the note of vented bonnets though, that means that all future car washes need to be done by hand... none of that servo 10minute job anymore???
Even if you foam up the car by hand you still gotta hose it down, so water still gets it. Maybe look out for certain vent styles that are directly above things like fuse box, spark plug cover etc...
I guess it could be a mod for people that have garages for their rides.
I'll make it up to you, one day I swear! I'm such a no-hoper :)
Although honestly, My engine(s) must have had a tighter seal around the top of the engine since I have never had that problem as much as you did :)
  • 2 years later...
I washed mine about a month ago at concord car wash, covered my pod filter with a plastic bag and used degreaser followed by high pressure rinse and hoped for the best. Luckily had no pronblems and drove off and its been fine.
With my previous car (mazda astina) washed it the same way and a shit load of water got into my spark plugs and was f**ked till i realised and got the water out.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
