yes been very busy getting ready for Super Drift
oil cooler and relocator kit
radiator flushed and new top
new gauges
rb24 motor new tomei rings/ 1.2mm gasket / new bearings / 82mm tomei forged pistons
17x8,9 drif teks, running 235/45/17 wanli rear
new uras kit / paint
sparco seat
rear camber arms
rear strut bar
ummm thats off the top of my head anyway :S
fark man im so jealous. I cant even afford a f**king diff :(
What oil cooler did you get ? JustJap ?
running a hks 2530 on it still but got issue's somewhere power seems 'restricted' to around 180-190rwkw !!! :dry: the torque is noticeable but have to sort this out now that i have time :thumbsup:
the 2530 has made 236rwkw on a stock rb20 motor so would've though similar peak power with added low/midrange... hmmm
Heres some pictures of my laufiro as she sits at the moment. I bought the car for 1k in rough as guts condition so i wouldnt have to drive my done up s14 k's to work every day. After a few burnouts and a very cheap rb30, a few blown diffs etc i decided this was my next project.
The pictures shown are when the car still had the rb30e installed with nissan rocker cover, rb20e inlet, injectors and computer. It came out later that day.
Car is sitting in a shed waiting for the engine to be built. (NZ)
Specs when completed (should be about 6/8 months)
rb30det
r32 rb25de head
rb25det (r33 trans) - have rb20det at present but will be upgrading
gt3540r 0.86
tial external wastegate
ecr33 power fc modified to suit
q45 afm
sard 700cc gtr injectors with resistor pack
acl pistons
acl race bearings
gtr head gasket
performance springs valve springs
block decked to give perfect 8.5.1 compression
I have most of the parts together here now, just waiting for my mechanic mate to get the motivation to start the engine build.
17x8.5 30 offset rear Racing Sparco rims
17.8 35 offset front
The body is an 89 cefiro that was as rough as guts when i got it. The laurel front was off a friends parts car and the whole car has been sprayed in my garage. The engine was installed as a friends boss had a cheap one and the rb20e wasnt doing its job spinning tyres.
I pick up some custom laufiro guards in a week or so time so that should complete the exterior. I dont plan on fancy kits etc as they are likely to get damaged and ruin the drivability of the car.
It should be good for 320+ kws when completed
Edited by SirRacer
  • Like 1
sir racer were can i get some of those lofiro gards can you please post a pick of those because im looking at doing a lofiro convertion aswell
they were custom made by someone in auckland nz by combining both cefiro and laurel guards together. apparently its a shit of a job so will cost around 600+ easily
i have thought about getting a fibreglass copy made but dont really want to fork out 400 to get them copied then loose my individuality. im in NZ anyway so that prohibits you getting a copy of mine
Thanks yeah I love it more than anything :dry: All work carried out in Japan.. Fronts are aftermarket flares that have been smoothed over. I'm guessing the rears are the same with the added complication of the door.. but yes large quantities of bog is involved :)
Edited by Drift_Limo
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
