Mates 33 4door, just finished doing a whole heap if stuff to it
New bar/paint
Top stage lip
hoshino boot wing
New wheels 17/18 work crkais in chrome
New bride seats
All new suspension arms/modded knuckles/extended LCA's
Complete cut and polish
AFB92F04-0634-45B3-B779-DE2445819D02_zps
531EF341-E29D-43B5-8556-D3CCA432FAED_zps
149C31C1-9564-475C-87AB-B7C49F3218C4_zps
  • Like 1
Daily only, won't be towing with it. Hard to find real figures on towing capacity, have read anything from 1350 to 2250 depending on the tow bar and if you can find a place willing to rate it high. Pass, I'll treat it like any other Jap sedan or wagon and assume it's soft in the rear and no good for towing along with poor fuel consumption from being a 2.5 turbo.
We've got a BF XR6 Falcon sedan currently serving family daily/tow duties. The wife will palm that off to me, we'll sell her Sil80 that i'm dailying and she gets the wagon.
If it's the one I've seen it's an SA22 RX7, approx 400kg lighter than the ceffy. If the wagon is only rated to 1350kg then that's the weight of the ceffy before even adding the trailer into it. If they're rated to 1850kg then dragging the ceffy about with tyres on the trailer will be over. Like I've said though, I've got the Falcon, it's a POS I don't care about so I'm not gonna tow with the Crown.
Mine will cost approx $15.5K landed and complied. By the time I chuck on rego, insurance, rims & tyres, kit, etc I'll easily be $20K into it.
Here is my -94 R33 gts-t 4dr that ii have done a new paintwork on and some chassi mods during this winter.
Curent spec:
Engine and gaerbox:
• Precision 5862 turbo
• HKS Manifold
• HKS 54mm external wastegate
• HKS down pipe
• HKS screamer pipe
• Stainless cat back exhaust
• Blitz airfilter
• HKS injectors
• Splitfire coils
• GTR fuel pump
• Greddy Rad
• Thrust front mounted oil cooler
• Thrust front mount inter cooler
• Z32 air flow meter
• Blitz DSBC-R boost controller
• Steel head gasket
• Nismo twoway LSD
• Nismo twinplate clutch
Chassi
• Kei office adjustable coilover front suspension
• HKS rear coilovers
• After market chassie brace kit
• Cusco antiroll bar front and rear
• Cusco tension rod
• Cusco rear camber arms
• Nismo front camber arms
• Tein steering rods
• Driftworks hicas eleminator
• Driftworks geomaster knuckles front and rear
• Driftworks offset spacers
Rims and brakes
• Work emotion CR Kai wheels 18’’ rear 17’’ front
• Rota GTR-D 18x9.5 ET12
• Rota GTR-D 18x10 ET12
• Rota GTR-D 18x12 ET20
• Braided lines
• GTR front brakes
• Project mu pads
• Wilwood 4 pot caliper rear
• Wilwood radial mount 4 pot calipers for hydro handbrake
• Poweer by max hydro handbrake
Interior
• Three defi gauges with controller
• Yoshio digital clock
• Nismo 320km clocks
• Sparco suede steering wheel
• R33 GTR seats
• Dildo gearknob
• Grip royal steering wheel
Exterior
• Ganador mirrors
• M sport skirs
• M sport rear bumper
• M sport frontt bumper
• Hakosuka rear wing
• Carbon fiber hood
• GTR head lights
Currently building a forged high comp RB3026 that i will run on e85 and hopefully with a NVCS mod on the 26 head for that will be mounted in for summer 2015 (we have snow between november and may here in sweden..)
1173866_10153879837995109_2020046261_n.j
1972285_10153879840325109_101776415_n.jp
1978614_10153879840115109_1116882445_n.j
47DCC4E6-ABB2-4598-A219-EB4ACC2951EE_zps
537260_10153535447865109_1636344394_n.jp
My front LCA's are lengthened 65mm and i waiting for new adjustable camber rods from japan so i can sort up my front alignement if you think it looks kind of weird now..
  • Like 1
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
