Well I'm not even sure Chris is going to make it now (he had car problems yesterday at Phillip Island) so it looks like I'm screwed anyways. You just have to get enough compeition yourself now because Pete has blown a turbo so he's gone from Calder too.
  • Replies 89
Posted Images
Hey Al would you sell just the tyres? As those rims might not clear my new rotors
Yep.........
For the same price :lol:
Unless you are running some ridicules callipers, these rims should clear them, as they have more clearance than the factory rims.
Im gonna try my hardest to be there!.. seeing as i could come 2nd (D) :D Can anybody confirm the passenger sessions?? i heared they were totally abolished but they are still in the sup regs info?....
question: in regards to the DB limit, how strict are they on that, in your experience??
Asking because I'm new to the track and my car runs an external gate venting to atmosphere, which obviously breaches the DB limit
thanks
Dane
Click Here For Entry List
PS. Ant - they either stuffed up what car your driving or you've been keeping secrets from us!!!!  :(
hehe, they are hopeless! they did that to me at the last sandown track day... the person who puts in the entrant car details see skyline on an entry form and automatically assume it's a GTR! :P
Yep - Mark Pether is a black R34 GTT as well - not a GTR as listed.
I don't know - I think these rex guys just like to list the RWD Skylines as GTR's so if they beat you they can feel good about themselves.
Sif a rex could beat a GTR. :P (Full race going versions with slicks not included Clayton! lol)
