This Group Buy is currently closed.
There are no R32GTR Bilsteins left.
Bilsteins are attempting to get an airfreight shipment during the next 3 weeks.
However there will be only limited numbers in the shipment.
So place your orders now to avoid dissapointment.
:blink: cheers :)
  • Replies 239
Posted Images
It is possible if i can but the shocks now(if they get more stock), then later on down the track when i have more money i can buy the rest of the gear?
Yep, no problems, that can be done.
As an alternative, some guys have a left a deposit ($400) and Jamex puts their shocks aside until they pay for the rest.
:whistling: cheers :P
oh i will do that, do you know if there will be any more before the 5 months? my rear left shock is more like a pogo stick then anything.
after realising i read you post wrong, i will be depositing money for them.
Edited by GTR1993
  • 3 weeks later...
PM replied to.
Bilstein received a small airfreight shipment of R32GTR Bilsteins today.
This Group Buy is re-opened.
:wave: cheers :laugh:
Whats a recommended package to buy?
Would it be shocks, springs and stablisers? What about Polyulethane(sp?) or Nolethane(sp?) bushes, are they included with any of it?
cheers
cheers
I have included everything that I think is necessary in the list of parts.
I haven't included anything that I think is unnecessary.
The shocks have been selected so that their valving matches the spring and stabiliser bar rates.
The suggested alignment settings are included, to suit the parts used.
The bushes are necessary to achieve those recommendations (there are no standard adjusters, except small rear camber).
PM me for further details.
:yes: cheers :D
  • 3 weeks later...
Anyone got pics of the rear strut brace?
Yellow ends, with polished alloy rod, adjusting nuts at each end of the rod where it bolts to the ends.
:rofl: cheers :P
Good news and bad news.
The bad news is the small airfreight shipment of rear shocks that Bilstein received in July has sold out.
The good news is there are 20 (10 pairs) of rear R32GTR shocks arriving early September via seafreight.
The bad news is there is ZERO stock at Bilstein in Germany and no production is currently scheduled this side of Xmas.
The good news is there are an equal number of fronts in stock.
So, if you want a set I strongly suggest that you get in now.
:mellow: cheers :)
Edited by Sydneykid
QUOTE(williamsf1 @ 26 Oct 2005, 11:54 PM)
G'day Gary....
I see the R33GTR race setup, nice work!!! and great laps times!
will there be an R32 GTR race package also? and will it be any different without the shocks? i.e. is it the dampers and springs only that are different?
The stabilser bar rates are different, the camber and toe settings are, of course, different and the rear sub frame alignment settings are different also.
The R32GTR shocks and springs will be quite a while, they haven't even made a prototype yet.
cheers
PS; PM me if you like, I will let you know what the kit will be otherwise.
Have you gone any further with this kit. I was at Sandown saturday and the car was very unstable all around the track. Shocks must be on the way out. Has there been any progress with the race setup shock valving as I am in desperate need of some shocks and srings. (Modified my group buy whiteline springs to fit my teins).
I noticed in your track suspension setup replies to other people you recommend a 24mm front swaybar but supplied me a 22mm. Was there any reason for this. I only just realised.
G'day Gary....
cheers
Whiteline are currently changing their high end shock and spring supplier, so no news on a circuit kit from them.
In the interim I have tested quite a few different valving setups with the Bilsteins for circuit work. I used a coil over conversion kit with Eibach coil springs. They work very well with "R" type tyres or full slicks (different rates used of course).
If I remember rightly, the 22mm bar was supplied because you had Teins with rediculously high spring rates.
What rear bar do you have?
PM me for more details
:mad: cheers :laugh:
Hi SK,
The bushes and strut bar still havnet arrived. I sent you a couple of PMs but no response. Can you let me know when i should expect the kit to arrive? (order was placed on the 5th).
Cheers,
Kot (Adam)
Hi SK,
Cheers,
Kot (Adam)
PM resent.
:) cheers :)
PM resent.
Thanks SK,
The kit arrived today. Two questions tho;
- Do the rear upper arm suspension bushes require a press for removal/installation? (Or can i do it myself)
- Rougly how many hours work so you think it would taker a shop to fit all four bushes? (I might just get the aligner to do it)
Cheers.
Kot
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
