  • Replies 294
I plan on taking my video camera with me to the dyno day, was just wondering if there is anyone here who does not wish to have there car filmed? The footage will not be put on the net as its not a digital camera and won't be shown to anyone and will only be taken for personal use!
What do you define as a run?
A run to me is to put it on the dyno and get a print out of what your power is.
Just ask him what you wanted to get printed out
ie kw vs afr
kw vs torque
etc
Normally you probably would get 2 burns in fourth gear.
Nathan,
Hows the gearbox input shaft seal?
No seaps? I had a seeping front input shaft seal that caused occasional strange slipping. Other times it was perfect.
joel, if it's leaking its not making it as far as the ground! but its only a stock VLT clutch, asking it to hold the power i have is a bit much i think, i always had planned to upgrade it one day.
Hey Nozilla, IceDuck, Sam, Deluxe where are your deposits?
I thought you guys would definitely be coming!
hey Will, I should be there to spectate, not really bothered about going on the dyno cos i got dynoed there only 2 weeks ago.
