Hey guys n girls,
These are suitable for just about any Nissan except the S15 and R34.
Doh! i cant even use one of these myself!!
$89 + $5 postage
also have genuine Silvia badges for any S13, S14 and S15 owners in 'ere.
Edited by JDMimports
https://www.sau.com.au/forums/topic/87819-nismo-blank-keys-available/
thats a good question. i have not trialed these keys on a R34 to see if they fit the barrel. Perhaps somebody on here may have an answer.
Nismo did produce keys to suit the S15 and R34 once upon a time. They do have a different item number.
These nismo blanks do fit the barrel of the S15 but unsure if the same applies the the R34.
  • 2 months later...
are they the same as the r32 GTR keys?? i have the original for a gtr key and its is fairly worn, so im looking at replacing it soon!! do you have the keys with 'gtr' insted of nismo?
thanks
Turbz,
We actually ordered some of those at the same time as the Nismo blanks.. when we received them, they all happened to be Nismo blanks rather than a bunch of each.
The back of the box indicates that these Nismo keys are infact suitable to the R32 also.
We are considering an additional order for more keys due to their popularity. These would include the GTR blanks also.
Hopefully we will have these available by Christmas.
cheers
  • 4 weeks later...
hey, i just got mine from nengun, and i just thought i'd let everyone know that they dont really look like the 1 in the top pic. they still look ok, but i was expecting the 1 in the first post, as thats what nengun show for the ad as well, but they are like that GTR 1 posted above, only gold in color...
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
