So,
Ever since the first stag cruise here in SA ive had a small stone chip on the windscreen (where we pulled of onto gravel between strath and victor as we drove of car in front of me flicked up a rock).
Driving home from work yesterday hurd an ad about how obrien do a windscreen repair for these chips to prevent cracks in future and it getting worse due to heat ect..... though to my self yeah should get it done.
Well today after work jump in car (boiling hot here today 40+deg) crank the A/C... takes a while to get cold as you know and then i feel the refreshing cool on my face and tink tink tink.... your not f**king serious! yeah away it cracked.
Cry cry cry
driving to work this morning, in the rh lane on the freeway, i hear a f**kin BANG! i thought oh f**k thats not cool.
a rock from a truck hit my screen. if i had have been in the middle lane where the truck was, it would have probably hit me square in the face.
good start to the day. as soon as i put a for sale sign on the car, this happens.
keep it
Quick question - do any of these non-oem replacement screens have the de-icer in them? My S1 has a couple of small chips that could almost warrant a claim on my insurance, but the de-icer is my main concern with aftermarket...
did ring obrians today.... turns out they dont have any s1 screens left in oz and they asked for my VIN number so they could get it in from nissan.... does this mean im gonna be up for a grand?
Dunno but when they replaced my windscreen they took down the tint number (apparently there are three or more different ones ) to make sure they matched it. Just ring your local windscreen replacement outfit and if they don't know the answer tell them to find out - shouldn't be too hard.
  • 11 months later...
well was alot easier than expected! Got it replaced thisarvo by InstanWindscreens. Had one in stock here in SA!
My vision is clear as day $395 later, was expecting iot to be ALOT more than that
And today on the way to work.... Another f**king stone chip. Got it booked into for a repair/glue tomorrow morning before it gets up to 38 in the arvo to reduce the chance of loosing 2 in less than a year!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
