Originally posted by GTS-t VSPEC
If you do get offered then it might be kinda to commit them to a mental instituation:p
Have they found a cure for ugly yet Ken?
See'ya:burnout:
As i said b4 , I'm fat but can lose weight.
You will be ugly forever:bahaha:
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Most rev-head chicks ain't to special, so be careful who you invite to join us, j/k
Chicks don't like to waste money on cars, they prefer to waste it on clothes.
See'ya:burnout:
Wrong
ANY revhead chick is special cos when I was young there weren't ANY around.
They were ALL into clothes
* sob , sob *
Cheers
Ken
Tasmania - dont think so - someone show me a map please:)
The auto sparky that I went to in Joondalup had an awesome $14k diagnostic tool that plugged into the car & also had a hand held cro - misht get him to go for a drive with me. Only problem is I don't know what the signals shiould look like but i think the magic book says what output coltage ranges should come up.
BTW - you're right Ken, I am about to lose my self control. Had to restrain myslelf from putting on the steel caps & hammering a couple of panels this afternoon - Naomi told me to go and have a lie down before I got out of hand.
Ken,
When you were young the dinosaurs roamed the Earth.
See'ya:burnout:
Go to bed it's after midnight and you sure as hell need your beauty sleep
Cheers
Ken
ps , Nope , it was the ice age
my clutch is ghey. it slips above 5psi in 1st gear... grr.
so i lowered my boost.... down to like 2psi, daym, i almost forgot what it was like to drive a non-turbo. all this in an attempt to make my clutch live a little longer so i can save more fold.
come to think of it, how can a "bleeder" valve LOWER boost, if it is by definition an air "bleeder"... ho hummm...
Kym,
Sorry to hear your not feeling well. A bleeder can only drop boost to a minimum oof 0.5bar (stock boost), by fully closing it.
Sorry to hear about the clutch, you don't seem to catch a break with your car, but just think, by the time you've replaced some of these things the car will be stronger for it.
See'ya:burnout:
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
