  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
talking about BBQ psiker - we are gatecrashing mackas place tonight for the sake of it.
Troys right paul gives as good as he gets.
U try to work? w-o-r-k must look up that in the dictionary sometime
Originally posted by skyzerr33
work was dull and boring fell asleep after we stoped whoring
r well
did some crappy reports
he i will go to work tommorow night and fall asleep as usual. i went to sleep for like 3 hrs last week and no one even knew cause im down the back all on my own
Psiker
he Department be advised that it is the Union's position that the Department must immediately inform any Staff member who has been to a SARS infected area to stay away from work for the duration of the recognised incubation period, 10 days, from the date of their return.
2. any person precluded from work under these circumstances will do so without loss of privileges or credits and that the Department will act with confidentiality respecting the privacy of the individual.
*Didnt know SARs was already in Australia?*
there has already been one confirmed case of a child in vic. the whole family is quarantined
Psiker
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
