See ya Kyles:)
Yep - we are sure that it never did it before Ken.
It started last night - we went from your house to the servo near me, he filled up & then it started playing up. Is there any chance that it could be associated with the pcv as aside from the immobilser, that is the only thing that was altered on the car recently?
Could be because the wing isn't on it any more:bahaha:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
See ya Kyles:)
Nah , car is back to the same as when I ran it. ie. pcv blocked , breather cleaner on.
Only change is the immobiliser. Are you sure all the wiring has been put back to std when you pulled the immobiliser
cheers
ken
Originally posted by GTS-t VSPEC
Damn, That was a pathetic Saturday night of whoring, took me 2mins to read back:p
Hope the cruise went ok:D
Ahh yes but some off us have a life and DO actually go out .
Think a lot might have cruised with epoch and I did the brownie point thing and went to La Cascade in Nedlands with the missus.
* Thinks , would rather be out cruising*:)
Seeya Paully and get off this damn puter and go on holiday:D
Cheers
Ken
hehe hey Ken .... me n Liz got into mischeif last night :D
We stumbled upon the South Australian Football Club and the club president was trying to pimp his guys out to me ....."What about this guy? hmmm do u like italians? ........ can i introduce u too? ..... Cmon just tell me which one you like and i'll see what i can do"
Had such a funny night ..... i think me n Liz really needed a night liek that :uh-huh: certainly got our minds off things! :)
anyway must go pick up mel for lunch in freo .... Liz maybe i should go bang on room 1033 and see if they are up yet haha i would imaginethere would be a lot of hangovers this morning!!
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
