  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Im honest with troy. I even tell him when my x's call and begg me back lol.. and we laugh about it.
Its easy to do what you did though, so they wont feel insecure. I was like that when i was first with troy . because of his bitch x and what she did i didnt want troy to think that that was goign to happen with me.. but he trusts me and now i dont really care about it and just tell him about who calls me, what happends when i go out and we laugh about it. Same on his end.
Well good luck Liz just do what u need to hun .... but trust me running away doesnt solve it ..... my break up was main reason i went to QLD ...... but the past has a way of catching up with u :)
Im off to bed folks
Sweet dreams all
*hugs*
Lauren
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
